Old 04-16-2019, 10:38 PM   #1
erniet's Avatar
Girard GSWH-1M - replacement???
I spent the last 3 months trying to get desired temp water flow from my shower, and never did. Is there a fairly economical replacement for this water heater?
My 2004 Itasca Meridian had a great water heater in it. I liked it! I hate my 2014 water heater.
I talked to Trauma in Quartzsite and their heater alone was over $1,000, not counting labor. Hopefully someone has a economical solution for me.
2014 Berkshire 400QL; sometimes towing 2007 Silverado and other times
towing my 20' Aluma trailer with a vehicle on it.
erniet is offline   Reply With Quote
Old 04-17-2019, 06:27 AM   #2
We replaced our Atwood on demand with the Girard Gen 3 on demand. No regrets. Constant hot water even when adjusting hot/cold mix and at low water pressure.Total cost around $540 with door.
Jim
2017 Berkshire XL 40 BH
2015 Jeep Cherokee Latitude
Locomo14 is offline   Reply With Quote
Old 04-17-2019, 08:38 AM   #3
erniet's Avatar
Thanks Jim, this is certainly better than the Trauma price I was quoted. Sounds like Gen 3 has made some needed improvements over Gen 1.
Old 04-17-2019, 09:31 AM   #4
Jim
You’re welcome. Before our trip to Florida I called Truma for an installed quote.....$1450. Wife was unhappy with Atwood but not that unhappy. Very happy with Gerard 3. Happy wife makes...........
Jim
Old 04-17-2019, 12:03 PM   #5
On demand Gerard
We had the first Generation Garard on demand heater in our Birckshire it never worked properly. After three failures I talked to Garard and they sent the Generation 3 and a new door. The Gen 3 works great has a programmable meter you can mount in the coach and set the temperature at a comfortable setting.
Good luck
caburn is offline   Reply With Quote
Old 04-17-2019, 01:01 PM   #6
erniet's Avatar
Did you install the Gen 3 or did you have a dealer do it? I'm just wondering how hard it would be to do myself. Thanks
Old 04-17-2019, 01:20 PM   #7
I installed myself. You can go on You Tube and watch an install then decide if you can do it. I painted the door myself. Got spray paint and clear coat at Lowe’s. Close enough match for me.
Jim
Old 04-17-2019, 01:48 PM   #8
Some guy in back...
The gen 3 is a big step forward from the earlier units and much better than 95% of the tank type heaters on the market.
(Why 95%?...any tankless unit other than the Truma cannot supply repetitive amounts of hot water. Think about washing your hands, or better yet, doing the dishes. You turn on the hot water, wait 10 seconds, get hot water, do the wash or rinse and then turn it off. 5 seconds later, you turn on the hot water, wait 10 seconds and then hot water appears and you wash or rinse. You must wait that 8-15 seconds every time you turn on the hot water for the hot water to show up. This does not happen with a tank-style heater. But-for taking a shower, you wait 10 seconds and then have hot water as long as your water and propane last. Just don't turn it off.
Some larger, 10 or 12 gallon tank style heaters with quick recovery can do a great job of supplying repetive amounts of hot water and provide a pretty lengthy shower (just not unlimited however) These larger water heaters are not so common, so that is why I said 95%. The Truma is truly the best of both worlds, but as you found out, can be costly to install. I like our gen 3 Girard very much but since it was close to $1000 to install with labor, I might have chosen the Truma if I had to do it over again. Using a tankless system when the outside temp and water temp is down near freezing can be a challange, but that is another story...)
ChateauV10
St. Charles, MO
Ex-SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 04-17-2019, 06:20 PM   #9
Dragonship Captain
Oscarvan's Avatar
I have a different solution to the problem....
May or may not be for you.....
https://dragonship.blog/modifications/hot-water-system/
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 04-17-2019, 07:06 PM   #10
I installed a Truma- it was expensive but so worth it! I has to driveway camp while remodeling my house- Over 6 weeks of perfect showers- My only complaint would be price but I would never own any other again
2012 390BH
dave-g is offline   Reply With Quote
replacement
