Old 08-06-2014, 09:38 AM   #1
Gray Tank Leak
If you are going to have an issue with the gray tank what better place to have it happen but at the FROG rally. I was sitting under the awning yesterday afternoon and water started pouring out the bottom of the MH at the pump compartment. It looks like it is leaking from a fitting on the top. FR diesel division is on it and I will update when they fix it.
Old 08-06-2014, 10:45 AM   #2
As the tank becomes full the drain from the shower is ridged and the tank flexes causing the seal around the pipe to leak. I think the fix will be to put a flex hose on to allow both to move with out leaking. Click image for larger version
Name:	ImageUploadedByForest River Forums1407339903.339454.jpg
Old 08-06-2014, 11:08 AM   #3
Gray Tank Leak
Test
Name:	ImageUploadedByForest River Forums1407341293.975186.jpg
Old 08-06-2014, 09:06 PM   #4
Campin Cajun's Avatar
Couldn't have asked for a better place to be when something breaks.
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
leak, tank
