Old 01-21-2014, 06:47 PM   #21
Hate when i do that. The space is about 9" high and about 22" wide.
2016 Forest River Georgetown 364TS
marcusfan is offline   Reply With Quote
Old 01-21-2014, 10:35 PM   #22
JTN8's Avatar
It would be a nice option but as seen in the picture I attached of my 2014 390BH's power compartment, I don't think it would be an easy install!!!Click image for larger version
Name:	ImageUploadedByForest River Forums1390365336.722711.jpg
Old 01-21-2014, 10:54 PM   #23
silver's Avatar
Mounting Power cord reel
why not mount it to the ceiling of the rear battery compartment, Looks like there would be enough room. Then use the original area to store your extension cords.
silver is offline   Reply With Quote
Old 01-22-2014, 08:49 PM   #24
ernest917's Avatar
I'm all confused.... All my batteries, inverter, charger , etc. are on the curb side of my 08 Berk.... My plug-in for land power is on drivers side in compartment with transfer switch and surge protector.... I have tons of space in that compartment for a reel...
ernest917 is offline   Reply With Quote
Old 01-22-2014, 09:21 PM   #25
JTN8's Avatar
On the 2014's, this is what my other side looks like. Rear open, middle is hydraulics bay and fwd one is the DEF tank.Click image for larger version
Name:	ImageUploadedByForest River Forums1390447288.610736.jpg
Old 01-22-2014, 09:25 PM   #26
ernest917's Avatar
Where does the power cord plug into???
Old 01-22-2014, 09:32 PM   #27
JTN8's Avatar
The earlier pic I posted of the drivers side bays, the middle one under the inverter/charger is the power cord. It is hard wired into the coach and there is a hole in the bottom of the bay that you pull the cord through. Then you have to pull it back through the other way and wrap it up in that tight area under the inverter once you're done using it. Pain to wrap it when it's cold out.
Old 01-22-2014, 09:35 PM   #28
ernest917's Avatar
Wow..... Mine is a loose cord that I plug into MH and other end plugs into CG power.... Loose cord rolls up and is placed in compartment for travel....
Old 01-23-2014, 12:17 PM   #29
If only that we're true. Unfortunately, my 2014 is set up exactly the same as the picture of JTN8's. There is very little space. Since we're 2 females traveling alone and I don't think I will ask my 80 year old mom to drag that darn heavy cord around, it sounds like my best option might very well be that flexible cord from Glendenning.
Old 01-23-2014, 03:09 PM   #30
Not sure why they changed the battery compartment. Mine is double stack with the chassis battery over the coach. Still not room for a reel but less wasted space.
berkshire, power
