Old 07-01-2015, 08:37 PM   #31
I have also replaced the RCA's with HDMI's. I have the BH model so the path's won't be the same. It isn't easy, but it is doable if you have the time. Getting to the outside TV was the easiest, followed by the bedroom, and then the front was a pain. Actually the mid TV was so easy I didn't even count that. I purchased the cables and 4x4 switch from Firefold. I was going to have CW do it, but even with me providing the materials, they wanted too much. I ran mine through the floor until I got close to the TVs then up. Miscalculated the cable length to the outside TV and had to use a female to female adapter to join 2 HDMI cables. One day I'll swap it for a single cable. It took me 2 days to do it. Wish I could help more with your floorplan.
JJvike is offline   Reply With Quote
Old 07-03-2015, 09:36 AM   #32
Originally Posted by edgewant View Post
I have ran HDMI cable from the entertainment center to the bedroom and the basement of my 2013 390RB. On a scale of 1 to 10 (10 being the most difficult) I would give it an 8.........
Since you have an RB like me, maybe the pics would be helpful. However, like Dan-Nickie said I'm getting too old and much to fat for a "level 8" job.
Still, I could get motivated, I guess....
As far as being fat..... I have one friend that uses me at the standard for being huge... When referring to someone who is especially large, he'll say "J C, he's bigger than you"!!!
Boowho??
boowho is offline   Reply With Quote
Old 07-03-2015, 09:57 AM   #33
edgewant's Avatar
I'll see what I can do.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 07-03-2015, 01:37 PM   #34
Don't go thru too much effort just for me.
Boowho??
Old 07-03-2015, 03:49 PM   #35
edgewant's Avatar
Here are some pics. Don't know how helpful they will be.
First shows penetrations under the vanity in the half bath. Panel is removed.
Next: HDMI cable and additional coax exiting vanity going towards toilet. HDMI has blue stripes.
Photo 3: The chase behind the toilet. The cables can be fished thru this chase from the bedroom. It is a tight squeeze between the bed and the wall.
Not shown in this post but I do have a pic are the chases on either side of the bed. They just lift up to reveal wiring and plumbing.
Photo 4: The cable guide that slides out of the rear bath wall next to the wardrobe. The top on each segment will pop off for access to the wires.
Photo 5: Floor of wardrobe overhead cabinet. After removing the staples holding this down I reinstalled with screws.
Photo 6: Wardrobe with lower drawer removed to reveal the penetrations in the floor and the wall.
I've got a couple more that I will post once I find them.
ID:	81956   Click image for larger version
ID:	81957   Click image for larger version
ID:	81958   Click image for larger version
ID:	81959   Click image for larger version
edgewant
Old 07-03-2015, 04:15 PM   #36
edgewant's Avatar
More pics of HDMI install?
Ignore the first.
Second shows chase on either side of the bed lifted to reveal wiring and plumbing.
Last shows leading edge of wardrobe slide with carpet unattached and 2 x 2 removed to show penetration through floor of wardrobe. It's upside down.
ID:	81962   Click image for larger version
ID:	81964   Click image for larger version
edgewant
Old 07-03-2015, 04:49 PM   #37
dan-nickie's Avatar
Thanks for doing those pictures. I know that was a lot of trouble.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 07-03-2015, 06:19 PM   #38
edgewant's Avatar
Glad to be of service.
edgewant
Old 07-03-2015, 09:17 PM   #39
+1 Thanks Dan.....
Boowho??
