Old 06-25-2015, 07:24 PM   #1
HDMI to outside compartment?
On a 2011 390RB, has anyone successfully routed HDMI cables to the outside front compartment and/or the bedroom TV?
If so, how much trouble was it??
Boowho??
boowho is offline   Reply With Quote
Old 06-25-2015, 07:25 PM   #2
I will be watching this one. It doesn't look easy.
Old 06-25-2015, 08:09 PM   #3
Yeah, and I don't know how much the newer 390RB's have changed so we may not have many "contributors"..... Do you still have your '11; or did you upgrade?
I'll be keeping my '11 until they carry me out of it cold, prone and stiff.
The scuttlebutt I've heard is that the build quality of new coaches (and not just from FR) has declined from what it was just 3-4 years ago.
Supposedly the industry is expecting a blowout year for sales and will be popping them off the line like cheap Chinese Wal-mart junk.
That's what I've read, anyhow.....
Boowho??
Old 06-25-2015, 08:16 PM   #4
I'm with you Boo I just hope I'm not to stiff to fit out the door. The revamped line up is confusing to me at least. It seem like the 400 series is closer to what we have at least after the tire upgrade and air bags. It also seems that a lot of features were dropped. We looked at a new Berkshire but the curved wall around the bath turned us off a bit. I like the layout ok but nothing that I would trade mine for. When we had Brad and Hall redo our furniture and new captain seats it is so comfortable and is our own design.
Old 06-25-2015, 09:16 PM   #5
john1345's Avatar
Well it is a pain in the butt. There is a number of ways you can do this. (Option 1) We watch sat TV most of the time so for Mid TV the HDMI come from the Sat rec to the mid TV. Now for the rear (bedroom) the installers ran the Cable (RG6) from the Sat unit on the roof to the edge of the roof above the rear TV and in to the cable duct and out of the wall in back of the TV in to the Sat rec and HDMI out to the TV. The oust side TV is another thing for the time being, was able to get at the back of the TV under the table so when we are parked I just run a 12 ft. cable around the couch and plug it in the back of the TV and the other end in to the standard switch box that connection is (SD). I have been told by my local dealer people have stopped by the factory in Elkhart and the will snake the HDMI Cable thru the harness for no charge. I guess they will do this because there was no cable run from the switch box to the outside TV. Now (Option) is to do the HDMI converter thing and use the existing cable in the coach (RG6) also replace the standard analog switch box out and use a HDMI switch box. That will still leave you with the cable running to the outside TV. I ran the comp 3 connector cable but if you run RG6 and us a HDMI converter. The wife and I have different venues of what we want to watch when we watch TV or watch DVD’s we have two DVD’s one in the bedroom and one at the mid TV and the one at the outside TV. For the sat Rec’s we use RF remotes so we can control the outside TV from the Mid TV sat rec.
Sorry for the long reply but this is the easiest way I have found to do it there are many ways and you kind of wind up with a kluge and you wind up pissing your next door buddy off when you change your channels and his change also.
John & Marianne
2013 Berkshire 360QL
john1345 is offline   Reply With Quote
Old 06-25-2015, 10:06 PM   #6
Originally Posted by john1345 View Post
Well it is a pain in the butt. There is a number of ways you can do this. (Option 1) We watch sat TV most of the time so for Mid TV the HDMI come from the Sat rec to the mid TV. Now for the rear (bedroom) the installers ran the Cable (RG6) from the Sat unit on the roof to the edge of the roof above the rear TV and in to the cable duct and out of the wall in back of the TV in to the Sat rec and HDMI out to the TV. The oust side TV is another thing for the time being, was able to get at the back of the TV under the table so when we are parked I just run a 12 ft. cable around the couch and plug it in the back of the TV and the other end in to the standard switch box that connection is (SD). I have been told by my local dealer people have stopped by the factory in Elkhart and the will snake the HDMI Cable thru the harness for no charge. I guess they will do this because there was no cable run from the switch box to the outside TV. Now (Option) is to do the HDMI converter thing and use the existing cable in the coach (RG6) also replace the standard analog switch box out and use a HDMI switch box. That will still leave you with the cable running to the outside TV. I ran the comp 3 connector cable but if you run RG6 and us a HDMI converter. The wife and I have different venues of what we want to watch when we watch TV or watch DVDís we have two DVDís one in the bedroom and one at the mid TV and the one at the outside TV. For the sat Recís we use RF remotes so we can control the outside TV from the Mid TV sat rec.
Yeah, it's a bit lengthy, but thanks for your efforts. I will be studying the post in detail.
As far as changing your neighbors TV channels you might look at this website: iRule: The Best Universal Remote Control for iOS and Android
It's an android/Ipad app that turns your tablet into the universal remote of ALL universal remotes.
The programming is not for the feint of heart, but when you have a VERY complex audio/video setup this app is the cats a**. Everything is done via WiFi.
boowho??
Old 06-26-2015, 09:58 AM   #7
Gents,
I've ran HDMI from the middle TV to the front storage compartment and its a piece of cake. You'll have to open the door to the cabinets, then remove the panel on the bottom right of the inside compartment. You can then drill a hole through the bottom into the storage bay underneath. Once underneath you can run the HDMI cable to the front storage compartment. For running it to the back TV, I've tried to figure out a route and can follow the existing cables through the bunk, but loose it coming up the inside wall to the TV. Sure it possible, but it doesn't look like a lot of fun.
The setup I have:
In order to get the satellite on all three TV, I use the 211 from dish receiver. It has red, white and yellow out as well as HDMI. The red, yellow and white feed my back TV. The HDMI feeds an HDMI switch I have. Accepts 4 inputs in and 2 out. That way I can watch satellite inside or out or satellite inside and cable inside. Below is a list of some of the parts I've referenced above:
Dish Network Solo HD Receiver (Vip211k) https://www.amazon.com/dp/B001D2XOS4..._6GwJvbPHR1ZB1
BlueRigger High Speed HDMI cable with Ethernet, Supports 3D and Audio Return (25 Feet) https://www.amazon.com/dp/B003XM73P2..._gGwJvbEVX62BK
Monoprice 4X2 True Matrix HDMI Switch w/ Remote (Rev. 3.0) https://www.amazon.com/dp/B003L17134..._5HwJvbHZDNHFG
-David
trekdave42 is offline   Reply With Quote
Old 06-26-2015, 10:14 AM   #8
John 1345 and TrekDave.....
Do you have the 390RB model???
Cause they're all going to be different, I'd imagine.
On the RB the bedroom TV is in the slide out.
Boowho??
Old 06-26-2015, 10:32 AM   #9
Boowho...
While not a cheap solution, it may be easier to use an HDMI over COAX balun such as the ones shown here. This will allow an HDMI signal to be sent over the existing COAX so no new cables have to be run. Not sure if you've considered this route or not. Obviously running HDMI would be slightly better, but this would be 100x easier.
HDMI IR Over Single 75ohm RG6 U Coax Cable Extender Balun Sender Receiver BNC | eBay
https://www.firefold.com/280567?gcli...Uc8gQodAm4NCQ\
Mike
foretm is offline   Reply With Quote
Old 06-26-2015, 10:40 AM   #10
Originally Posted by foretm View Post
Boowho...
Mike
Thanks Mike, I was un-aware that such a thing even existed.
Boowho??
