Old 08-30-2015, 03:03 PM   #1
Retired IT Manager (NERD)
Headlight
Wonder if anyone else has had this happen.
I found my left side headlight was not working upon inspection found the connector was not securely attached and was hanging loosely from the headlight socket. Looking at the connector it had shorted across the connector melting the plastic I am assuming this was caused by it being loose and shaking before becoming dislodged.
Neanderthal is offline   Reply With Quote
Old 08-30-2015, 03:19 PM   #2
tmmar's Avatar
When you say the connector, what are you referring to? There is a large, multi-pin connector that was giving me a problem with my left headlight or are you talking just about the connector on the one headlight? I had an issue with the large multi-pin connector and had FR work on it at the rally. So far-so good.
Tom and Margaret
2014 Berkshire 390bh-60
Old 08-30-2015, 03:24 PM   #3
The connector on the headlight.
Old 08-30-2015, 03:25 PM   #4
tmmar's Avatar
Didn't have that problem.
Tom and Margaret
Old 09-01-2015, 06:17 AM   #5
KennyGolub's Avatar
When I drove home after purchasing ours, I found the wire from the right front headlight was hanging and the oval shaped cover for it still remained on top of the housing.
The bulb itself was bent in the socket, about 15 or 20 degrees and did not work at all.
Replaced the bulb, made sure it was set correctly in the housing, and put the oval cover back on. All is well.
Good luck,
Ken
Ken & Laurie
Retired Cleveland CPD
2019 Entegra Aspire 44W
2018 Jeep Wrangler Unlimited
KennyGolub is offline   Reply With Quote
light
