Old 03-20-2014, 06:41 AM   #1
Headlight Question
I recently purchased a 2010 Berkshire and the headlights are on all the time the coach is running. Has anyone figured out how to shut the headlights off when driving? I'd actually just like to figure out a way to flash the headlights to signal to passing trucks or other RV's.
RNuzzolo is offline   Reply With Quote
Old 03-20-2014, 08:12 AM   #2
NV245's Avatar
I usually turn on the headlights at the switch, set to high, turn them off and use the headlamp switch to signal passing traffic an all clear. What I'd like to know is how to turn them off when backing into a spot at night when backing into a spot. (The glare off of the inside windows is blinding)
NV245 is offline   Reply With Quote
Old 03-20-2014, 10:24 AM   #3
Thank you, I'll try that next week when we move next. I have not been able to find any way to shut the lights off including backing up.
Old 03-20-2014, 09:16 PM   #4
Campin Cajun's Avatar
I believe it's a safety feature, but there may be some kind of programmer that can be plugged in to get them not to come on while the engine is running.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 03-20-2014, 09:23 PM   #5
Phat Phrog Stunt Crew
awwall's Avatar
A little crude, but you can always add a switch to the dash and break the power feed to the headlamps.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 03-20-2014, 09:46 PM   #6
Cyclone
beipers's Avatar
On ours, I run with the marker lights on then push the headlight dial to flash the fog lights when someone passes me. Then when I'm passing someone else, I flash the marker lights by turning the dial to acknowledge the other rig. By running with the lights on I only have one motion either way.
I'll have to double check, but I was thinking that the daylights would shut off if you turn the hazard lights on. If so, this could provide a solution while backing up.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 03-20-2014, 09:47 PM   #7
NV245's Avatar
I notice that the daytime running lamps turn off when the parking brake is on. I think that I would prefer to find access to that circuit.
Old 03-20-2014, 09:55 PM   #8
Cyclone
beipers's Avatar
I've always assumed that the park brake indicator is run off an air pressure sensor switch as I don't believe there is any electricity in the actual air valve. Obviously I haven't traced the circuit down, but likely the daylights, buzzer and icon on the dash are all controlled by the computer. I'm always concerned about messing with the computer inputs, because you never know what other safety features you may be messing with. I think you'd be better off with awwall's suggestion.
2015 SOB 5th Wheel
Old 03-20-2014, 10:06 PM   #9
VinceU's Avatar
Keep in mind, some juristrictions require daylights whenever the engine i running. One notch of park brake shuts them off.
Old 03-20-2014, 10:11 PM   #10
Oklahoma Proud
MillerTime's Avatar
You might look for a fuse labeled " DRL" for daytime running lamps. U could pull that fuse.
On ebrake switch circuit, you can test, but on some vehicles sometimes when ebrake is engaged just enough to trip the switch, but not enough to catch the brakes; if the vehicle continues movement the drl will kick back on again. I dont know if this will happen with air brakes as my truck didn't have drl's.
On finding presure switch, you may look by the manifold, usually close to the steering column- sometimes outside the cab, sometimes under the dash. But you will have to test the switches, as some systems have 2 switches, for brakes, pressures, and you may have more, Im not sure on that kind of system.
If it was me, I would find the ground for the headlamp, isolate those 2 wires and place a switch on the ground wires, then you can just ground the other switch lead to any body grounded area. You will just have to remember that you need the switch to be "normally closed" for your lights to work. Also this way you won't ever have to worry about "shorting" any circuits out.
MillerTime- Future Sabre Handler!!
light
