Old 07-05-2019, 12:06 PM   #1
Headlight Upgrades?
Quick search here couldn't find anything (although my search may have sucked). We have a 2017 40BH and I have trouble seeing at night and constantly have the high beams on to drive. Has anyone upgraded their headlights to something that actually works? If so can you please provide any guidance as it would be nice to be able to actually drive at night!
Thanks,
Garrett
ssbundy is offline   Reply With Quote
Old 07-05-2019, 05:05 PM   #2
CRL1's Avatar
2017 Berkshire XL - Headlights, Cameras???
CRL1 is offline   Reply With Quote
Old 07-05-2019, 05:16 PM   #3
Multi-Slacker
Hmmmm......
Have you recently had an eye exam? Trouble seeing in dim light can be a result of cataracts or macular degeneration among other things.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / 2700 lb 2.5" Receiver
CurtPutnam is offline   Reply With Quote
Old 07-05-2019, 07:30 PM   #4
Garrett,
The alignment on the headlights is pretty hit and miss from the factory. You’ve probably already looked at the threads on this as to how to check them, but it’s worth a look. They could be way off. Also, you’re sitting quite a bit higher than normal and that can have an effect. The link sent to you helps. I believe you can convert the type of bulb but not necessarily a simple swap out.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 07-05-2019, 07:47 PM   #5
PPST Wannabe
kenandterry's Avatar
Originally Posted by CurtPutnam View Post
Hmmmm......
This is a very common problem with motorhomes from a variety of manufacturers. Donít compare the lighting of your pickup truck to motorhome headlights.....they are not tested anywhere near the same.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 07-06-2019, 04:46 AM   #6
I did the 9011 1nd 9012 bulb upgrade. inexpensive and a big improvement. in this post-
2012 390BH
dave-g is offline   Reply With Quote
Old 07-06-2019, 07:30 AM   #7
Eagle5's Avatar
Mine suck at night too. I think they need to be aimed. I havenít looked to see how thatís done. Is it fairly easy to aim them myself?
2019 34QS with no ladder!
Eagle5 is offline   Reply With Quote
Old 07-07-2019, 09:05 AM   #8
ceedog's Avatar
I went with HID's on my 2011. They work great!
They're plug & play, & available on Amazon. Match your current light bulb to the indicated kit.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
light, upgrade
