Old 01-23-2018, 11:12 PM   #1
Heat efficiency on 390FL MH??
When it's 45F outside and the rig needs interior heat, which source (Heat pump,furnace,fireplace) draws the least power (or is the most power efficient)??
Appreciate your responses in advance.
gregkono is offline   Reply With Quote
Old 01-23-2018, 11:36 PM   #2
ernest917's Avatar
Heat pump totally ineffective when temps drop into the 40's.... I'd use a combo of fireplace and ceramic heater.... I'd use furnace as last resort because it relies on propane which I tend to conserve as much as I can....
We place two ceramic heaters (one in bedroom area and one up front) and they keep things toasty - plus your using CG's elec not your propane....
ernest917 is offline   Reply With Quote
Old 01-23-2018, 11:46 PM   #3
FYI;
We are on a metered spot (electricity)..
Old 01-24-2018, 01:00 AM   #4
ernest917's Avatar
Then I guess u use the furnace because your heat pump's not going to get the job done and I'm guessing the fireplace also uses elec....
Old 01-24-2018, 09:28 AM   #5
You are correct as the fire place instantly puts out heat via electricity. Just was unaware of which source drew the most power. Thanks...
