Old 10-12-2013, 10:49 AM   #1
gasman94's Avatar
Heat Pump
I've got a question on my 14 berk 390fl. Should both heat pumps be available on the thermostat? I have only 1 zone showing the HP. Both A/c units are the same, so is it just a programming issue? Any help appreciated.
gasman94 is offline   Reply With Quote
Old 10-12-2013, 11:35 AM   #2
My 2011 came with a front only HP. Unless you ordered a HP for zone 2 it does not have one.
Old 10-12-2013, 04:25 PM   #3
kingwood390bh's Avatar
My 2010 is the same as Phil's. Heat pump up front only.
Will
kingwood390bh is offline   Reply With Quote
Old 10-12-2013, 04:49 PM   #4
gasman94's Avatar
Thanks guys. I thought since the units were identical, they should have the same capability.
Old 10-12-2013, 05:02 PM   #5
Berkshire 390QS
NO3putt's Avatar
Have heat pumps on front and back.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 10-12-2013, 05:06 PM   #6
Was your MH ordered that way? Are the units both 13.5?
Old 10-12-2013, 05:24 PM   #7
Berkshire 390QS
NO3putt's Avatar
Both are 13.5 units and puchased off lot, not ordered.
Old 10-12-2013, 05:27 PM   #8
ernest917's Avatar
My 08 has front and back....
ernest917 is offline   Reply With Quote
Old 10-12-2013, 05:31 PM   #9
I stand corrected. I know that mine has only a front HP. This is something that FR must change from year to year. I guess the only way to tell for sure is to check the model number of both units.
Old 10-12-2013, 06:24 PM   #10
gasman94's Avatar
Yep, model # is the same. I'm taking it back to the factory in the spring...I'll check with them then.
Old 10-13-2013, 07:40 AM   #11
rvdrmin's Avatar
Added new 15K Penguin HP to front moved 13.5K HP to back of '13 Berk 360QL. Check WWW.DOMETIC.COM web site under INSTALLATIONS INSTRUCTIONS: COMFORT CONTROL II. 0n Page 17 Letter M, it's shows 'Dip Switches' that have to be set for each unit individually. #7 is for the HP setting. It needs to be On for the rear unit to allow HP option. We had Dometic Service Tech @ FROG Rally set ours so they both work now in HP mode.
Buzz
rvdrmin is offline   Reply With Quote
Old 10-13-2013, 10:17 AM   #12
gasman94's Avatar
So you're saying that the dip switches on the unit must be changed so the thermostat can recognize the capability. I am bringing the coach to the factory in Elkhart next spring for some warranty work so they should be able to do this. I wonder why it isn't done from the factory, or was it just an oversight? Thanks for your input. Might as well use the RV parks energy source for heat instead of wasting LP if the capability is there.
Old 10-13-2013, 11:11 PM   #13
62_inrightlane's Avatar
Originally Posted by rvdrmin View Post
Added new 15K Penguin HP to front moved 13.5K HP to back of '13 Berk 360QL. Check Dometic.com Dometic web site under INSTALLATIONS INSTRUCTIONS: COMFORT CONTROL II. 0n Page 17 Letter M, it's shows 'Dip Switches' that have to be set for each unit individually. #7 is for the HP setting. It needs to be On for the rear unit to allow HP option. We had Dometic Service Tech @ FROG Rally set ours so they both work now in HP mode.
Did the exact same thing on our 360FWS Better cooling up front and better heat in the rear! They should come this way!
Marc & Jan
Molly, Abby & Katie | The Cocker K-9 Kids!|Toad 2014 Cadillac SRX
2012 Berkshire 360FWS, Brake Buddy Vantage|Wineguard Travler SK-3005
62_inrightlane is offline   Reply With Quote
Old 10-14-2013, 07:15 AM   #14
rvdrmin's Avatar
It would seem logical that when the 13.5K HP was moved to the rear which replaced the non-HP unit, the dip switch #7 would already be 'ON' . But all the tech said he had to do was turn the HP switch ON for the rear unit since it had been moved from original location. Before the switch was changed we didn't have HP as an option on the CCC II unit. After he climbed off the roof, Voila! It was there. He didn't enter our coach to make the fix. BYTW just had perfect fall weekend here in South Haven MI and used both HP's for a bit early mornings to warm up. Nice upgrade.
I've frequently said...why aren't there 2 HP's or bigger this or fully ducted AC or aluminum wheels, etc. But I remember that aside from floor plan differences .....to get many of these items I would have paid a lot more ($30 or 40K or More ) for my RV. So I still feel it's a heck of a coach for the money. JMO.
Buzz
Old 10-14-2013, 10:06 AM   #15
gasman94's Avatar
rvdrmin: Enjoyed the same weather here in Battle Creek. South Haven is a nice relaxing town. Plan on going there in a couple of weeks and enjoying a good meal at Clementines....
Old 10-14-2013, 11:12 AM   #16
We were in SH two weeks ago. Stayed at Sunnybrook and eat at Clementines. Great week and great food.
Old 10-14-2013, 12:49 PM   #17
gasman94's Avatar
Phil, did you like Sunnybrook?
Old 10-14-2013, 01:48 PM   #18
Yes we did. If you can try to get on the lake. Lots of friendly people and a nice hot tub. We had never been to SH before and will go back for sure. Gasman are you a member of FMCA? If so PM me. We have a local chapter called the Roving Wolverines and we do three rally's a year. Mostly in MI. A fun group. Like I said PM me if your interested.
pump
