Old 10-12-2013, 10:49 AM   #1
gasman94's Avatar
Heat Pump
I've got a question on my 14 berk 390fl. Should both heat pumps be available on the thermostat? I have only 1 zone showing the HP. Both A/c units are the same, so is it just a programming issue? Any help appreciated.
gasman94 is offline   Reply With Quote
Old 10-12-2013, 11:35 AM   #2
My 2011 came with a front only HP. Unless you ordered a HP for zone 2 it does not have one.
Old 10-12-2013, 04:25 PM   #3
kingwood390bh's Avatar
My 2010 is the same as Phil's. Heat pump up front only.
Will
kingwood390bh is offline   Reply With Quote
Old 10-12-2013, 04:49 PM   #4
gasman94's Avatar
Thanks guys. I thought since the units were identical, they should have the same capability.
Old 10-12-2013, 05:02 PM   #5
Berkshire 390QS
NO3putt's Avatar
Have heat pumps on front and back.
Old 10-12-2013, 05:06 PM   #6
Was your MH ordered that way? Are the units both 13.5?
Old 10-12-2013, 05:24 PM   #7
Berkshire 390QS
NO3putt's Avatar
Both are 13.5 units and puchased off lot, not ordered.
Old 10-12-2013, 05:27 PM   #8
ernest917's Avatar
My 08 has front and back....
ernest917 is online now   Reply With Quote
Old 10-12-2013, 05:31 PM   #9
I stand corrected. I know that mine has only a front HP. This is something that FR must change from year to year. I guess the only way to tell for sure is to check the model number of both units.
Old 10-12-2013, 06:24 PM   #10
gasman94's Avatar
Yep, model # is the same. I'm taking it back to the factory in the spring...I'll check with them then.
pump
