Old 11-11-2014, 02:36 PM   #1
Kelsma03's Avatar
Heated tank pads
Silly question, how to you turn the pads on to heat the black, grey and fresh water tanks in the underbelly?
Kelsma03 is offline   Reply With Quote
Old 11-11-2014, 03:27 PM   #2
Berkshire 390QS
NO3putt's Avatar
On ours, the panel with slide switches, water heater switch, slide swithes there is a switch for heat pads, ours is a 2009, maybe the same on yours.
NO3putt is online now   Reply With Quote
Old 11-11-2014, 03:36 PM   #3
Witch Doctor's Avatar
mine is named TANK HEATERS... but I do not own a MH either.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-11-2014, 03:44 PM   #4
Kelsma03's Avatar
We have a 2014 400BH. I don't recall seeing a switch for tank heaters where the slide, tank indicators, water pump and water heater switches are located. But that would be the logical place.
Old 11-11-2014, 04:16 PM   #5
tmmar's Avatar
On my '14 390, there is a red switch that is not labeled that is for the tank heaters.
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-11-2014, 08:33 PM   #6
ernest917's Avatar
My switch is there with all the others.....
ernest917 is offline   Reply With Quote
Old 11-11-2014, 10:12 PM   #7
x2
Dan
2015 Entegra Anthem 450HP-1250ft lbs of torque
2015 Jeep Grand Cherokee
Roadmaster Falcon 2 All Terrain
SMI Air Force 1
seeg is offline   Reply With Quote
Old 11-12-2014, 04:20 PM   #8
Anacortesians
On ours, there's a domestic-style light switch on a panel below the kitchen counter with a label "ARTIC PACK". To a Brit, an "artic" is a tractor-trailer rig (short for "articulated lorry"), but I believe it should read "ARCTIC". It turns on the tank heaters.
They're only on the grey and black tanks, on the assumption by the designer that the potable tank is inside the living space. The built in thermostat keeps the heaters on until the tank contents are above 60 F. I can't see using electrical power to heat the sewage to that temp.
I've never used the system.
Frank and Eileen
No longer RVers or FR owners
Old 11-12-2014, 04:27 PM   #9
ernest917's Avatar
My potable water tank is in same compartment as the grey and black ones....
Old 11-12-2014, 04:56 PM   #10
This is FR remember that, and you have answered your own question.....
Coachmen M/H
Concord
2018 / 300 DSC
tank
