03-17-2019, 01:05 PM
Help, no power to Safe T Alert propane detector
2011 Berkshire 390qs. I have no power to the propane detector which in turn shuts the solenoid to the tank. Manual says there is a 5amp inline fuse somewhere.
Any ideas?
03-17-2019, 01:44 PM
Dragonship Captain
No idea.... but pull the panel out of the wall and take a peek there. Then look in compartments below..... Also look in compartment under driver's window. There's quite a few in line fuses I have no idea what they do.
Also, the reason that it has an in-line fuse is because it is, I believe, wired so you can't shut it off with the battery switch.... so look below where any direct take-off may be.
Meanwhile you can run temporary power to it to get the solenoid open.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
03-17-2019, 02:28 PM
Berkshire 390QS
Have replace ours and never did found the inline fuse. Skip
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
03-17-2019, 03:28 PM
Just as confused as you
I'm not familiar with your lp detector but if it is the combo CO/LP detector they have a life span of 5 years. They are supposed to chirp every minute or so but I've heard where some just shut down. Since your Berk is 8 yrs old I think it's time for a new one.
Richard & Jill
03-17-2019, 03:41 PM
Found online another thread that it was in the in inverter compartment on the wall. Here's a picture. 5 amp
Dan
2014 Berkshire 390RB-60
03-17-2019, 05:01 PM
Dragonship Captain
That looks like a VERY viable candidate! Nice of FR to label that and/or have a picture and directions in the manual like everything else.....
03-18-2019, 12:08 PM
Mine looks a little different but I found the blown fuse. Thanks for sending me in the right direction.
03-18-2019, 12:32 PM
Now you have to ask your self,,,,why did the fuse blow?
03-18-2019, 01:26 PM
Dragonship Captain
Well... yes. But you give it the benefit of the doubt and say it was old and tired. Replace it and...... if it does it again.... then we officially have a problem.
Sawmill, glad you got it figured out.....
03-18-2019, 10:57 PM
If a replacement fuse immediately blows, the likely culprit is a shorted solenoid coil. You can verify this by disconnecting the solenoid power line behind the detector. Safe-t-Alert does not sell replacement solenoids; you need to purchase the replacement kit which includes the detector and solenoid. It's also possible that a kit replacement will have a solenoid with different sized fittings on it. Hopefully, if you order a replacement from FR, you'll get one with the correct fittings.
I know this because the solenoid failed this way in my 2011 Georgetown after two years. I ran into these issues getting a replacement at an independent service center. This past Summer, the solenoid again failed. I was able to locate a replacement on the web and replaced it myself. I wouldn't recommend a DIY repair unless you're comfortable working on propane or natural gas lines.
Phil
12-31-2020, 12:21 AM
My daughter opened the fridge after the trip and a bottle of juice fell out and burst opened spilling half of its content inside this detector.
It started to smell with burnt wiring so I pulled it out and had a pleasure watching the contacts on circuit board slowly melting. The dot on the copper was so bright I thought it was another LED until I realized that it is smoking and moving.
It was about a year overdue for replacement anyway but I had to jerry rig the system for cooking and hot water until the replacement arrives.
Of course the fuse was also gone, could also be me trying to figure which wires I need to connect to get the solenoid open.
I could not find the fuse either so I was about to pull solenoid and call FR after new years because it was neither behind the panel nor next to the solenoid.
Thank you for posting the picture, it was exactly next the inverter. I connected red to striped yellow/red wire and capped the white and propane is flowing.
Will have to get some 5 amp fuses
Alex and Valerie
2014 Berkshire 400BH
12-31-2020, 12:23 AM
BTW, you can buy solenoids separately. Just get the markings and google. I saw it for sale for about $50 bucks
Alex and Valerie
