Old 07-07-2013, 10:05 PM   #11
Director, FROG
F.R.O.G.'s Avatar
There should be a breaker switch on the top of the generator. Have you checked that? If it's tripped, the generator will run but it won't send power to the coach's AC electrical system.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 07-07-2013, 10:29 PM   #12
2011 Berkshire 390BH
Superchief's Avatar
Bob, Been there, done that! Had my generator do the same thing you mentioned, last year. Spent 30 minutes plus checking every fuse, circuit and outlet before considering the breaker on the generator (didn't even think it had one, but looked anyway). Problem solved and was able to make a cup of coffee!!
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 07-08-2013, 10:21 AM   #13
2011 Berkshire 390BH-60
TaterColo's Avatar
With all that was out I kept thinking it had to be a breaker. I looked at the generator yesterday and could not find the breaker.
Looked again today and found the breaker located under the oil filler. It was tripped. I reset and tested and all works fine.
Thanks all!
Todd
TaterColo is offline   Reply With Quote
Old 07-08-2013, 10:25 AM   #14
tmmar's Avatar
Under the oil filter? Which generator do you have? I have an Onan 8kw generator and my breaker is right on the top of the unit towards the front.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-08-2013, 10:43 AM   #15
Director, FROG
F.R.O.G.'s Avatar
Thanks all!
Todd
Todd, thanks for letting us know how it turned out. I love happy endings!
Bob Byrne
Old 07-08-2013, 03:58 PM   #16
ernest917's Avatar
Just an additional note: My generator has a fuse that is held in by a spring-loaded cap.... If that cap vibrates loose, say goodbye to cap, fuse and say hello to a generator that will not start.... Ask me how I'm aware of this little situation - yep.. Had it happen to me...
In addition , those spring-loaded caps are almost impossible to find... Plus - the fuse is a weird sized one as well - 14amp I think). (I now carry extras plus I've put a strip of gorilla tape across the cap...)
ernest917 is offline   Reply With Quote
