Old 01-24-2016, 11:58 AM   #1
Help on hot water heater
We have a new Atwood heater and we get hot water and then goes cold for 60 seconds and then hot, etc. Any thoughts
zimmnc is offline   Reply With Quote
Old 01-24-2016, 12:01 PM   #2
wmtire's Avatar
Have you checked you bypass valves? This can be a common reason for your symptoms, in being the bypass valves are incorrectly set.
I also think I read where there is a recall on certain Atwoods too, if you have a tankless one.
RKNOLA reposted the above recall again just the morning:
BADLUCK
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 01-24-2016, 03:20 PM   #3
7 Year Class A RV'er
Tankless, or on demand, heaters are a strange lot and take a lot of getting no used to. We have the Girard Gen II and once we got through the learning curve and replaced the faulty switches and sensors it works great, though contrary to logic. First, remember the temp is meant to be set so you use only hot water, not mixed. You can get the results you described if you're mixing cold water in, like you would do in your house. We've found we can slowly blend in just a smudge of cold at the faucet if we really need to but you have to be gentle with it. Remember the temp adjustment us not for a specific water temp like your house, but t's actually for the Delta T, or temp rise from incoming water temp to usage temp. If you have 65F incoming water, you only want about 40 degrees rise to get 105F water at the faucet. In the winter, incoming temps of 45F will require more temp rise. You can increase the temp rise to some extent with the adjustment switch, but you can also make the water hotter by simply reducing the flow at the shower head to make the water go through the heat exchanger slower. Hope this helps some. Good luck!
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 01-24-2016, 03:37 PM   #4
A couple of things to check. First you do not have bypass valves or switches so don't go looking for them. Your Atwood WH has a bunch of sensors and cutoffs that can cause those symptoms. First make sure that the black rubber tube is clear. And bugs or even water will make it stop working. Also do you have good water pressure? You need 40 psi or more to really have it work good. Also check the temperature adjustment and try turning it down. It sounds like the water is getting to hot and the high limit is shutting the burner off.
Are you just running hot? If you are trying to run both hot and cold at the same time that can cause the hi limit to kick in also. Try most hot and turn down the temp to get the right mix. It takes some getting used to. I have had the Gerard gen one and two as well as the Attwood. I like the Attwood the best.
Old 01-27-2016, 07:24 AM   #5
CAT-RN's Avatar
My question is : Are we talking about an on demand unit or a 6 gallon water heater??
Russell
CAT-RN is offline   Reply With Quote
Old 01-27-2016, 08:03 AM   #6
AquaMan's Avatar
Russell
It's posted in Berk forum, so I'm guessing on demand.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-27-2016, 08:04 AM   #7
TURBS's Avatar
Is yours Tim in the g town?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-27-2016, 08:07 AM   #8
Answer
Yes it is on demand
Old 01-27-2016, 08:19 AM   #9
AquaMan's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
No, I have 2 6 gallon tank heaters. One for each bath.
Old 01-27-2016, 08:24 AM   #10
TURBS's Avatar
Suweet!
2015 Columbus 320RS
2008 2500HD Duramax
heater, hot water, water, water heater
