Old 10-20-2015, 05:46 PM   #11
CSMRetired's Avatar
Battery level maybe
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 10-20-2015, 06:32 PM   #12
accumack's Avatar
Have you looked for warnings on the Freightliner information LCD panel?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-20-2015, 08:10 PM   #13
silver's Avatar
Hard to diagnosis with so little info but it does not sound like a Forest River issue. I but my money on Freightliner and the air system. You may have had a hose slip out of a fitting. The 1.3 sec could be the time to pump up then bleed down air pressure.
Does it happen if you just sit and idle? If yes I really think Air.
Do both your air gauges fluctuate or just one?
I believe top gauge is for front breaks and bottom is for back breaks. You need air to activate front breaks and you need air to release rear breaks. Yes the two are opposite.
Do you hear the hiss in the front or back of the coach? I believe you said front. I would check to see if the manual bleeders for the air tanks are OK. There are two pull cables behind the passenger front tire and one behind the driver front tire. Try pulling both these and see if problem stops. Other than this I think you should get to a Freightliner shop.
silver is offline   Reply With Quote
Old 10-20-2015, 08:41 PM   #14
Campin Cajun's Avatar
The beeping could be something as simple as a smoke detector. Check everything, if you don't have warning lights on or flashing on the dash most likely it's not from FL.
I had some beeping also, it sounded like it was coming from the middle of the coach while I was in the front, I would go to the middle and listen and it would sound like it was in the front. I finally found it in the master bedroom, it was the smoke detector. And it was warning that the detector itself was bad, not just a dead battery. I had to change the whole thing out.
Just telling this story so you don't assume it's something terrible and waste a lot of time hunting it down in the dash.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-21-2015, 06:25 AM   #15
tmmar's Avatar
Did you check your residential refrigerator? There is a beeping when the doors are not closed tightly.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-21-2015, 11:36 AM   #16
Professional Texan
TexasBob's Avatar
May be odd but check your propane detector. It does not have a battery but runs on the RV battery. It does have an odd pattern of beeps when it is at EOF (end of life) I know you said your unit was new but my new travel trailer propane detector had a EOF signal after six months. It that is what it is, press the reset button and it will give you a week or so to replace it.
Just my 2 cents. It is a possiblity.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 10-21-2015, 04:19 PM   #17
gasman94's Avatar
Tom and Margaret
I've dealt with both of these issues. Good possibility.
Rich
gasman94 is offline   Reply With Quote
Old 10-21-2015, 08:36 PM   #18
Certainly must have figured it out by now. What was the findings ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-21-2015, 08:37 PM   #19
I hope he comes back and lets us know what was making the beeping noise.
Old 10-22-2015, 07:31 AM   #20
baddmann's Avatar
I agree.
Some of the earlier suggestions have happened to me (carbon monoxide, low battery on propane detector, smoke detector, etc) so those seem like the most likely.
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
