Old 11-14-2015, 11:26 PM   #41
gasman94's Avatar
You should have a demand water heater in yours and there is no water heater bypass. On my Girard, I did open the pressure relief valve and let out water. I also blew out my system with air and replaced the system with rv antifreeze.
Rich
gasman94 is offline   Reply With Quote
Old 11-15-2015, 12:22 AM   #42
Originally Posted by Ride_with_me. View Post
I am new to the Motor home group. Winterizing today. Where is the water heater and the by pass. I have a Berkshire 2016 34QS.
I see you are from Jacksonville NC. Are you retired Marine?
Old 11-15-2015, 08:59 AM   #43
Wolverine 1945's Avatar
You should probably Search Winterizing,,, on FRF Motorhomes !!!
Wolverine 1945 is offline   Reply With Quote
Old 11-15-2015, 09:24 AM   #44
A 2016 should have an Atwood WH. Google it or You Tube if your lucky they'll be a video on winterizing the unit.
Paul
Paulie Boy is offline   Reply With Quote
