Old 12-15-2019, 08:07 PM   #1
Help with Allison MH 2500 transmission fuses
Have had a recurring problem with the two fuses linked to the transmission blowing. When this happens the display light on the transmission that indicates F NN R is not lit up. Has anyone had similar experience with this???? If so whats is like to be causing the fault????
jimwillis00 is offline   Reply With Quote
500, fuse
