Old 10-20-2014, 07:59 PM   #31
JBoyer's Avatar
Cajun - thanks for trying...
jrlebaron - I've sent the paint codes to about half-a-dozen web sites that mix paint and put into spray can applications. Have not heard from any of them yet. Thanks for the advice and suggestion.
2015 Landmark Newport
2015 Silverado 3500hd dually tow vehicle
previous rig
2008 Berkshire pusher
2010 Mini Cooper Convertible toad
2015 Nissan Frontier toad
JBoyer is offline   Reply With Quote
Old 10-21-2014, 08:08 AM   #32
I-RV's Avatar
My tab that holds the cover on broke while at the dealer. It was plastic and they replaced it with a metal one. They said that the plastic ones are not good. As a precaution to all, check whether the heater door tab is plastic or metal. X2 to the additional safety tie or paper clip.
Hank
I-RV is offline   Reply With Quote
Old 10-26-2014, 01:11 PM   #33
The little spring loaded tab lock on the Berk water heater cover is a joke. Luckily mine broke off in my hand while the unit was stationary ... I still have my cover.
Rather than attempting to replace the spring loaded gizmo, I fed a bolt through from the inside. Locked it in place with a nut ... leaving only about 1/4 inch of the bolt sticking out past the cover. I then secure the cover in place with a felt backed rubber washer and a wing nut. It work like a charm.
This will not bring back your lost covers but it will prevent then being lost a second time.
lefaivre is offline   Reply With Quote
Old 10-27-2014, 12:38 PM   #34
Campin Cajun's Avatar
That's a good idea lefaivre.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
cover, heater, water, water heater
