Old 07-08-2014, 08:48 PM   #11
klucas's Avatar
I took the switch off and the fan stopped. I out it back on it clicked then fan came back on. No flame. Does this mean something else is wrong?
klucas is offline   Reply With Quote
Old 07-08-2014, 10:02 PM   #12
jevanb's Avatar
You took the switch off??? You should of jumped the ground to the power , that by passes the switch. And will turn on the propane ignition. Call Girard tomorrow they will talk you thru troubleshooting other issues...
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-09-2014, 06:46 AM   #13
klucas's Avatar
I jumped it first and nothing happened. I will call once they open today. Very frustrating.
Old 07-09-2014, 10:03 AM   #14
klucas's Avatar
Name:	ImageUploadedByForest River Forums1404918000.727105.jpg
I just got of the phone with tech support. The white sensor is a over heat switch and reset. I just had to push the button and all is good now. The tech told me it overheated and protected itself by this switch. Apparently in the shower with the mixing valve you can't use any cold water. Hot water only and use the dial to adjust the temp. I hope this info will be useful to someone else one day.
Old 07-09-2014, 12:10 PM   #15
Help with tankless. Any ideas?
Klucas
Thanks for the update. It's frustrating when a main utility does not work. Thanks for sharing the fix.
Old 07-09-2014, 04:24 PM   #16
Mmnsc's Avatar
I have found the overheat safety tends to trip when you change campsites and get air in the system. When you purge the air out make sure the power switch on the heater is off. When the switch is on, you get a temporary spike in water temp that trips the switch thus requiring it to be reset.
Mmnsc is offline   Reply With Quote
Old 07-09-2014, 04:41 PM   #17
klucas's Avatar
Great tip. Also good to know that reset is there. Thanks
Old 07-09-2014, 04:44 PM   #18
klucas's Avatar
Originally Posted by Phil57 View Post
Klucas
Yes, it is very frustrating. It usually happens at the worst time. Murphy's law. Good to have the fix and hope this easy fix will help others. Also the fact to not use any cold water on the mix valve also. The gen 2 is very different in that regard from the original gen1 we had in our coach at purchase. But this one seems to have much better performance.
Old 07-12-2014, 05:17 PM   #19
jevanb's Avatar
glad you got it fixed, sorry I did not think of that issue because mine did that same thing once, we just got back in town camping for the last 1.5 weeks and internet no work at most of the places
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 07-12-2014, 11:26 PM   #20
Mbh818's Avatar
Mike Hollar
2014 Berkshire 390BH-40
2012 Chevy Equinox - TOAD
Mbh818 is offline   Reply With Quote
tank, tankless
