Originally Posted by Phil57
No you should be good. I would always recommend you get a weight but would expect you to be well below weight. The issues started with tile floors and larger fridges. Also DEF is reported to add almost a 1000 lbs. I'm surprised be that. Most of the issues I have seen are with 11-13 mostly RB's and BH models.
When you say def adds 1000 lbs, I'm guessing you're referring to the entire def system, not just a full tank of def, right?
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
