11-21-2015, 09:15 AM
#41
Not all units are over weight. I'm not sure they would know which units to recall other than the 390-RB Berkshire. Only some of the others are affected like the 390-BH. Forest River is correcting the issue at their expense even ones that are out of warranty. Other manufacturers have a weight problem but won't do anything about it. I think Phil was the first to discover it. I didn't know until I decided get my coach weighed due to seeing some being pulled into a portable inspection station with portable scales here in Temecula CA and decided to know my weight.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
11-21-2015, 11:20 AM
#42
Originally Posted by ependydad
Heh. Soooooo not my intent. My apologies if I'm the catalyst for that.
Your post wasn't bad, but it usually one like it sets off the kind I was talking about.
2013 Berkshire 390BH
11-21-2015, 12:47 PM
#43
And I might add; those bomb tossers usually don't even own a Berk.
Paul
11-21-2015, 01:42 PM
#44
While you're looking at upgrading your suspension, you might want to think about dynamic forces in addition to the static load with your vehicle just sitting in your driveway. When you take curves, weight transfers to the outside tires. If the suspension and tire tire load ratings are marginal when sitting still, there can be substantial overloads when moving. In the case of my trailer, the outside tires are overloaded by about 30% on curves which may be the root cause of my tire failure on Monarch Pass in Colorado. The same physics would apply to a motor home.
I looked into the federal rules for testing of ST tires. They are only tested to 100% load, so any assumption that ST tires can withstand an overload is without basis. I'm not sure whether this is also true of tires for a motor home.
11-21-2015, 03:32 PM
#45
This has nothing to do with your ongoing fight with FR. It's not a tire issue and it has been resolved and is open to any Berk owner that has a over weight issue.
11-21-2015, 03:35 PM
#46
<sigh>
11-22-2015, 09:20 PM
#47
In case anyone is wondering...It appears they have resolved the weight issues at least in the 2015 models. We have a 2015 38RB - 340. Before a long trip, we had the basement loaded, fridge loaded, clothes, full of fuel, propane, and 1/3 tank of FW, plus me and the wife on board. The only thing we didn't have on board when we weighed is our two 60lb puppies, so we can add 120lbs to the below weights, they travel in the bunk beds so they would be added to the rear axle.
Steer Axle: 10,140
Rear Axle: 16,940 (17,060 with puppies)
Total Weight: 27,080 (27,200 with puppies)
2015 38RB has a 10,500 front axle and a 17,500 rear axle, for a GVWR of 28,000.
That leaves us 360lbs under on the front axle and 440lbs under on the rear...or 800lbs under GVWR!
Terry & Kim
2015 Forest River Berkshire 38RB
2007 Wrangler Unlimited
11-22-2015, 10:22 PM
#48
How do you get those weights? Is the 38a only 38 ft? Why am I so dang heavy?
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
11-22-2015, 10:28 PM
#49
Help - Wt. Police
Attachment 94836
Because it's to very different Moho's. Have you gotten info in getting it fixed?
If you have a 2014 or newer Moho you should be good. I (and everyone else) highly recommend getting your Moho weighed to adjust for ride and to make sure you are safe.
11-22-2015, 10:31 PM
#50
Yea, after looking up the 38rb, I saw it didn't have a slide behind the driver like my 390fl. I'm sure that's a lot of weight difference.
Mine is 2012 so I've still got to get an empty weight for it, not easy to set up when you live in it fulltime.
11-22-2015, 10:34 PM
#51
Pm sent
11-24-2015, 09:08 PM
#52
I got an email reply from Mitch today, he seems to think I'm within spec. He said Randy should be back tomorrow and he will see what he says.
11-24-2015, 09:18 PM
#53
CC your PM is full. I want to send you one.
11-24-2015, 09:24 PM
#54
Should be good to go now Phil, I just cleaned up my inbox.
11-30-2015, 01:49 PM
#55
Randy Houser is the BOMB dot COM.
I will be heading to the plant come spring time. (my choice on timing)
01-19-2016, 07:23 PM
#56
Help - Wt. Police
I got an email from Randy say when my coach left them it was under by 1100 lbs had it weight yesterday 10320 lbs, what I'm I dining wrong. The weight was taken with no- one inside?
01-19-2016, 07:53 PM
#57
Was your coach empty of all belongings? Also what does your sticker in the cabinet above the driver seat say. does it have the 12000 lbs front axle or the 10,400?
Ham KG5LTL.
01-19-2016, 09:26 PM
#58
I'm sorry but I don't remember what Moho you have. I see it's a 2012 but need more info.
What model
What config did you weigh it. Was it empty of your gear. Fill fuel? Def? LP? Post a copy of your weight sheet and your yellow sticker.
I will send you a pm with my phone number. That might help.
You also said Randy indicated your Moho was under 1100. What do you mean by that. The cargo capacity was under 1100?
01-20-2016, 12:06 AM
#59
Help - Wt. Police
Yes it was empty of all cargo, and a full tank of fuel, DeF, and propane. No fresh water, no gray water or black water. The sticker says I have a 10,410 Front axle capacity.
I have the 390-BH 340 built in 2012.
It had a weight of 10320
01-20-2016, 12:10 AM
#60
That sounds like my 390FL.
But, I found out my tires are upgraded to 275's.
The guys at Forest River said there should be a tag on the axle that would tell me if its been upgraded too. Haven't crawled under there yet to see.
