Originally Posted by ghhardin
oh, then I should be able to run an AC unit for about 5 hours
You need to check the amp output at various RPMs.
Don't think that just driving down the road a 200 amp alt is putting out 200 amps.
First, it depends on how fast it's spinning. (It is in fact an electrical motor generating power.) the faster it spins the more power is generated.
Secondly, ( it depends on how much power is required during normal operation).
Even if you were traveling fast enough to spin the alternator at maximum power output, the regulator only turns on and allows the battery to be charged after there is enuf power available to supply whatever requires power during operation. (Lights, heater, AC, radio, cameras, etc.)
If there is not enuf amps available, the battery does not get charged).
This is simplefied, but You need to be aware.
It's not just "plug and play"
Example, in my case I had an original 60 amp alt and
I added some additional options.
Led headlights, heated seats, electric radiator fans.
I replaced the alt with a 100 amp unit. (More than enough power to supply my vehicle and all the options). So I thought. .....
I forgot about idling at stoplights, intersections and driving in slow traffic.
My vehicle kept overheating.
The radiator fans were not getting enuf electrical power, (amps) to spin fast enuf to pull air thru the radiator.
I had to upgrade to a 200 amp alt to be able to generate enuf amperage at idle.
Problem solved.
Just need to know your numbers on the output curve...
Good luck!!
