Old 11-07-2015, 01:31 PM   #11
MNtraveler's Avatar
Originally Posted by tmmar View Post
Area51,
If I remember correctly, you just have to close the one valve that lets the cold water into the heater. Once that is closed, nothing should go into the heater. If that is not working, the valve may be defective.
If you don't close the hot water valve, then antifreeze can back up through the bypass line and hot water line into the heater if it's ever the path of least resistance (say, all faucets are turned off while anti-freeze is being pumped).
Further reason you need to close all three valves: the hot water, the Coldwater, and the bypass valve.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 11-07-2015, 01:32 PM   #12
MNtraveler's Avatar
Originally Posted by Billr View Post
I-RV is correct, there are 3 valves on the back of the water tank. Hot, cold, bypass. Have to use all 3.
Agreed.
Old 11-07-2015, 01:33 PM   #13
MNtraveler's Avatar
The best diagram others have posted before me (thanks!).
Name:   ImageUploadedByForest River Forums1446921204.012241.jpg
Old 12-15-2015, 03:16 PM   #14
Anybody know how to get to the hot water bypass valve on a 2014 Flagstaff Classic Super Lite 5th wheel?
Belleville Bob
Belleville Bob is offline   Reply With Quote
hot water, water
