Old 05-23-2016, 09:51 PM   #21
captnrick3's Avatar
Originally Posted by ndfellow View Post
Update I called Girard and they gave me some pointers none of them worked. They gave me an upgrade to the Gen3 new unit for $500 which I felt was fair. Goes in Wednesday 7 day trip starts Friday!
Cool, hope you like it. We have yet to travel with our Gen. 3, but have tested it to the hilt in the driveway and love it. We leave on a 2 month trip to the Canadian Rockies in a few days. Looking forward to not fiddling with hot water so much.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 05-24-2016, 10:58 PM   #22
ND fellow
I was not offered an upgrade by the Girard engineer however I did find him very helpful.
After fighting with that stupid heater for several years and attempting ever possible fix discussed on this forum .... the engineer hand held me thru a long drawn out testing process. It involved digital thermometers, measuring cups and stop watches.
At the end of the day, he provided me with the very simple fix that I outlined up above.
The fix coat me next to nothing and took less than 30 minutes to put in place.
This past weekend we were camping with that outside temp at slightly over 40 degrees f. For the first time since buying my 390BH in 2011 I had a shower that needed to be turned down because it was far too hot. Once the temp was set, the 4 of us had back to back showers. .. with no worries of running cold.
It took a hell of a long time but now that the system works ... I like it
Tim
lefaivre is offline   Reply With Quote
Old 05-25-2016, 12:53 PM   #23
SEAYALL's Avatar
I talked with girard tech just last week , talked to him about the bypass. He told me he would not recommend , it void the warranty. An after a time will burn up burner cause it's always on high. Just relating what I was told
SEAYALL is offline   Reply With Quote
Old 05-25-2016, 03:09 PM   #24
Funny that they are changing their tune. The Girard engineer told me that the bypass changes the system from and auto/low setting to a high/low setting. You still have a switch on the main panel that allows you to drop the burner down to a low setting. Up here in the great white north the ground temp remains quite cold so the low setting does not often come into play. In a place lice Arizona or Southern California it could be a different story.
The recommendations were based on a number of tests and many measurements .... it is entirely possible that the conclusion would have been very different down south.
GOOD POINT
Old 05-25-2016, 08:16 PM   #25
SEAYALL's Avatar
It is interesting, I am in Ga. Dealer is in Fl. But tech never asked me, this is not to say I will not try the bypass , like you said you would be controlling the flame on dial inside the coach. With gen 3. Is that not what there doing anyway? Thanks
Great conversation
Old 05-25-2016, 09:42 PM   #26
dan-nickie's Avatar
I think the manufacturer is giving you two different suggestions because you have two different Generations of water heater.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-26-2016, 12:36 PM   #27
captnrick3's Avatar
Great conversation
Gen III flame is controlled by a temp. sensor on the output side of the heat exchanger. So far, works very well.
2015 Legacy 340KP
2012 Wrangler Sport
Old 05-26-2016, 01:18 PM   #28
SEAYALL's Avatar
Ok. Maybe next step. Except I have to do a new door I understand
Old 05-26-2016, 01:47 PM   #29
captnrick3's Avatar
That is true. I painted my own, some take it to an RV paint shop.
Check on the Legacy forum under "On-Demand Water Heater". On page two I posted a list of materials for the change out to Gen. III, and a few pictures. Hopefully your heater has good access to the rear so the plumbing won't be a pain. Mine was easy.
2015 Legacy 340KP
2012 Wrangler Sport
Old 05-26-2016, 01:54 PM   #30
SEAYALL's Avatar
Yes, it a 2015 Charleston. In bathroom under washer/dryer there's a pop out panel an you can see the whole back ofHeater , I'll check out your post, thank you.
heater, hot water, water, water heater
