Old 03-28-2016, 09:24 PM   #1
Hot water smells like petroleum gas
We just purchased a 2008 Forest River Berkshire 390BH and took it for the first trip last weekend. When we took a hot shower, there was a distinct petroleum gas smell coming from the water. It was not a rotten egg sulfur smell - it was definitely a petroleum type gas smell. It was only from the hot water when the hot water heater was on. The cold water did not smell and it did not taste bad. It is currently in the shop getting some minor repairs and they are stumped as to what it is. Any ideas??? thanks!
pigletat100acres is online now   Reply With Quote
Old 03-28-2016, 10:27 PM   #2
Usually Confused Member
emm-dee's Avatar
I've heard some discussions about the anodizing rod sometimes has a bad reaction to certain water. Don't know the reason, something about bad well water, water from copper or lead pipes, or whatever. As a test, try removing the rod, get all new water into the heater then see if it still stinks. If that solves the problem I guess you could leave the rod out but I'm sure that will induce other problems down the road...and shorten the life of the heater.
Just a suggestion, and others more knowledgeable will be able to come up with a solution if the problem gets fixed.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 03-29-2016, 08:51 AM   #3
It's hard to tell without more info. What water heater do you have. Is it a tank or tankles? If it's a tank type I agree change the anode rod. In either case flush the system and sanitize it.
Old 03-29-2016, 09:13 AM   #4
Go Seahawks!
Subsailor's Avatar
Maybe some "left over" RV antifreeze either in the tank or if it is tankless, left in some of the hot water lines. The RV antifreeze smell changes quite a bit from brand to brand and could be considered to have a bit of a petroleum type smell. In any case, a good flush and sanitizing should assist like Phil said.
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 03-29-2016, 12:54 PM   #5
bend302's Avatar
Do you have an "aqua hot" system? That might be diesel you smell. Try making sure water heater is on electric only.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 03-29-2016, 01:35 PM   #6
No aqua hot on Berkshires.
Old 03-29-2016, 01:39 PM   #7
It sure gets confusing with the same post in different places.
gas, hot water, water
