Old 09-03-2015, 09:59 AM   #1
nathantoensing's Avatar
House Water Filter....
I think it's time to replace the whole house water filter... however the tech at the dealership put it in prior to us picking up the coach so I didn't get to see how to install. I tried turning the housing counter-clockwise but it didn't seem to budge and I don't want to force it then break it. Is there a trick or how do I get that thing off?
Thanks y'all!
--Nathan
2016 38a
nathantoensing is offline   Reply With Quote
Old 09-03-2015, 10:02 AM   #2
JohnF's Avatar
Hard to say without seeing it. Make sure the pressure is released by turning off the water supply and opening a downstream faucet.
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 09-03-2015, 10:12 AM   #3
tmmar's Avatar
As JohnF said, relieve the pressure. You can open the drains on each side in the water bay. You should have also received a water filter wrench in the box with all your manuals. The wrench fits over the filter and makes it easier to remove.
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-03-2015, 02:11 PM   #4
'11 390BH
These are a spin on style, just changed mine
Every neighborhood has one...in mine, I'm him!
kohersh is offline   Reply With Quote
Old 09-03-2015, 02:51 PM   #5
Tmmar.... Is that also how you drain the fresh water tank, from the water bay side?!?
--Nathan
2016 38a
--Nathan
2016 38a
Old 09-03-2015, 03:05 PM   #6
tmmar's Avatar
Nathan,
There is a door just in front of the rear wheels on the passenger side. There are 2 clips on the underside edge of the door. Undo the clips and raise the door (you will need something to hold the door up because there are no hydraulic pistons to hold it open). In that compartment you will see the water pump and valves that will allow you to drain the fresh water tank. That is where you would pump the non-toxic anti freeze through the system if you winterize your coach.
Tom
Tom and Margaret
Old 09-03-2015, 03:07 PM   #7
Thanks Tom!
--Nathan
2016 38a
--Nathan
2016 38a
Old 09-03-2015, 03:30 PM   #8
I-RV's Avatar
Nathan
It is CCW looking up from beneath the water filter. When looking from the top, it is CW. Hope that you have the plastic wrench that fits over the filter housing. - Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-03-2015, 05:36 PM   #9
Originally Posted by I-RV View Post
Nathan
I'm puzzled. Wouldn't it be CCW from either top or bottom view?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-03-2015, 07:14 PM   #10
dan-nickie's Avatar
How about turn it to the "left" to remove?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
water, water filter
