Old 08-26-2015, 06:32 PM   #11
Call 800 FTL HELP. They will get you going. Those guys are great and it's 24/7!
CT Camper is offline   Reply With Quote
Old 08-26-2015, 06:32 PM   #12
As far as the bucking bronc issue is concerned. It you follow these simple steps.you will never.have the problem again.
Start the unit and let air pressure come up to cutoff.
Turn the engine off, turn Jacks on and hit retract all.
Once the Jack panel beeps and the lights go off, restart the engine.
Let.the engine run until it is up to temp and the air pressure has reached cutoff before disengaging brake ŗnd putting rv.into gear.
Good luck
lefaivre is offline   Reply With Quote
Old 08-26-2015, 06:46 PM   #13
Originally Posted by lefaivre View Post
This may seem crazy but.did someone hit the battery disconnect beside the front door.
Not.sure why this switch even exists since the three switches in the battery compartment are the only ones that enyone should ever use.
Tim
No, the LED is lit but I WILL go outside and wiggle the two big switches in the battery compartment. Good Idea!!!
Boowho??
boowho is offline   Reply With Quote
Old 08-26-2015, 06:50 PM   #14
Thanks to you and Tom..... Will be my next action...... NOW!!!!
boowho??
Old 08-26-2015, 06:50 PM   #15
Boo can you cycle the jacks a couple of times. Maybe even the slides as well. If it started then won't after you ran the jacks I would suspect a switch hung up. I also wonder if turning off the battery switch and then back on might reboot the system similar to a computer.
Old 08-26-2015, 06:59 PM   #16
Thanks to FL CS... I'm running. Sh**, dodged THAT bullet.
I had shut the engine down while still in "F".... MUST be in "N".
Took the guy (jhn) about 30 seconds to diagnose.
Thanks all.....
Boowho??
Old 08-26-2015, 07:00 PM   #17
Sweet. Now with all that money you just saved by your bride a nice dinner.
Old 08-26-2015, 07:03 PM   #18
Ford Idaho's Avatar
Thanks all.....
Boowho??
Old 08-26-2015, 07:18 PM   #19
Great news!! It's a fantastic free service and I love the fact they are there 24/7. The one of there techs in Gaffeny said there even working on Christmas and other holidays if needed.
Old 08-26-2015, 07:35 PM   #20
toslow's Avatar
wow now thats service over and above, great to see this still exists.
haven a blast
toslow is offline   Reply With Quote
