Old 08-27-2015, 12:37 PM   #31
Can you bypass the lock out by jumping the starter solenoid. If so, PLEASE have engine in park with emergency brake on AND someone sitting in drivers seat with foot on brake.
2015 274 RK LIMITED <'{{{{><
captainperry is offline   Reply With Quote
Old 08-27-2015, 12:39 PM   #32
Forgot to mention. Ignition ON
Old 08-27-2015, 12:42 PM   #33
40'diesel MH. I would not recommend doing this as you would put yourself in danger.
Old 08-27-2015, 01:38 PM   #34
Did it all the time....proper safety precautions and common sense......doesn't matter of its 40' or 100'
Old 08-27-2015, 01:58 PM   #35
dan-nickie's Avatar
There is no 'Park' on a Berkshire. Doesn't matter as he has already found out what the issue was.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-27-2015, 02:16 PM   #36
They have air brakes correct....like I said you need common sense
Old 08-27-2015, 02:19 PM   #37
And neutral I might add
Old 08-27-2015, 02:24 PM   #38
So if you can enlighten us with no common sense where is the solenoid? If it's in the Battery bay that's one thing but even then you better know what you are doing. If it's in the engine compartment it would require you to be inside the engine compartment while someone I is trying to start the engine. I'm sure it's doable but not for the novice.
Old 08-27-2015, 02:33 PM   #39
dan-nickie's Avatar
There is no lock out on his coach. The problem has been
Dan
Old 08-27-2015, 02:44 PM   #40
gasman94's Avatar
Originally Posted by JTN8 View Post
Just wondering why you turn the coach off once you are all aired up? I always do the same steps as you except never shut it down. You get the ignition on alarm when you turn the panel on but when you hit retract all it goes off. I've used these steps since new and never had an issue. Also, I do not wait to air up when I start the coach, I go straight to retract all since the coach dumps air when you do this step anyway. Once all retracted, turn it off and you hear the click and the coach starts to air up the bags and tanks.
Jason
Same way I do mine, Jason. No engine shutoff. Just hit jack retract after you've started the engine.
Rich
gasman94 is offline   Reply With Quote
