Old 09-06-2015, 08:59 AM   #1
I-RV's Avatar
How do I Block The Shower Dome Heat ?
This summer, I had a pillow tied with cord to the rim screws to block the tremendous heat that comes in through the shower dome.
I know that I can make the insulation, like maybe using expandable foam to form fit the insulation. But my big question is does anyone have a good idea for how to hold it up there and able to quickly remove it when desired.
I know that Boo is going to say park under a tree
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-06-2015, 09:03 AM   #2
Campin Cajun's Avatar
You can paint the outside top of it white. That will help some. Some higher dollar coaches come with a "trap" door that can open and close for it also. I'm sure one of those could be retrofitted to a Berk.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-06-2015, 11:52 AM   #3
2011 Berkshire 390BH
Superchief's Avatar
Hank, a lot of heat comes through that "sky light". I recently measured mine with a temperature "gun". 115 degrees - 89 outside temp. I now just close the bathroom door. It has helped a lot. Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 09-06-2015, 12:01 PM   #4
Plain Old Member
See this thread:
Skylight Protection from Hail
Post #14 I think. Ours is coated on the outside with a product from Proguard, batten insulation on the inside, then bubble insulation. Of course this skylight has the interior decor replacing the inner dome, but the one above the shower underwent the same treatment, but still has the inner dome, which is also painted from the inside. No light, no heat.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-06-2015, 12:04 PM   #5
Plain Old Member
Here's the exterior dome coated. This is not paint, but a very thick coating.
Old 09-06-2015, 12:13 PM   #6
Plain Old Member
Here's the pictures from the other thread.
ID:	87946   Click image for larger version
ID:	87947   Click image for larger version
Old 09-06-2015, 01:44 PM   #7
I-RV's Avatar
Big John: You do not have a Berkshire. The cavity for the shower's inside dome has very sloping sides. You cannot get anything to stay within the cavity with the exception of a sky hook. Hank
Old 09-06-2015, 01:55 PM   #8
Plain Old Member
I realize I don't have a Berkshire, but I have owned 2 motorhomes and a scad of other RVs with different dome designs. Pull the inner dome. Use your imagination. I've done this to all of our rigs, sloped or not. On our shower dome, pulled the inner dome, filled the cavity between the 2 with batten, painted the inside of the inner dome, secured bubble insulation to the inside of the inner dome, reinstalled. Looks the same, minus the light and heat. I've done a bunch of them, on ours and other's rigs. Hadn't seen one I couldn't make work.
Old 09-06-2015, 01:56 PM   #9
Plain Old Member
I can dig up a few more pictures of different designs if need be.
Old 09-06-2015, 01:58 PM   #10
Berkshire 390QS
NO3putt's Avatar
we painted ours white (on the outside) using rubber spray paint we picked up at Lowes. put several coats on and has helped with the heat and still lets in some light. figured that using the rubber paint could pull off if didn't like it
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 09-06-2015, 02:02 PM   #11
Plain Old Member
Here's an older one.
ID:	87956   Click image for larger version
ID:	87957   Click image for larger version
ID:	87958   Click image for larger version
Old 09-06-2015, 02:04 PM   #12
Shower cover
I loosened 4 of the screws around the skylight trim just enough to string some elastic cording around the screws. I tightened the screws back. That made a "holder" for the cover I fashioned out of foam core and reflective $ store windshield cover. I can slide this cover off and on easily. It makes a world of difference in the amount of heat that comes in the skylight. I still have the option of removing it when I am parked in the shade or in the wintertime.
2016 Flagstaff 8528TBWS-Platinum
2013 F-250 diesel
(pop-up-25 years, hybrid-5 years, bumper pull-3 years)
4aggiesmom is offline   Reply With Quote
Old 09-06-2015, 02:18 PM   #13
Plain Old Member
And another. Yall get the idea.
Name:	Inside of Outer Dome Painted.JPG
ID:	87961   Click image for larger version
Name:	Bubble Insulation.JPG
ID:	87962   Click image for larger version
Name:	Batten Insulation.JPG
ID:	87963   Click image for larger version
Name:	Inner Dome Reinstalled.JPG
Old 09-06-2015, 02:21 PM   #14
DaveSchwartz's Avatar
Not a Berk, but similar here... I removed the 6 screws on the long sides and put them back with a nylon coax clamp under them, then put an entry door reflective shade over the opening (it is the same size) and used 3 mini-bungees to hold it in place (the glue on the supplied velcro won't hold).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-06-2015, 02:33 PM   #15
DocsDad's Avatar
Not pretty... but fast up and fast down with velcro (2 standard vent covers velcro'd together. Very functional and takes hardly any space to store.
2016 Forest River Sunseeker 3100SS
DocsDad is offline   Reply With Quote
Old 09-06-2015, 02:39 PM   #16
Who Dares, Wins
doc73's Avatar
Did the same as above in ours, not a berk, used industrial velcro that is seeming to hold. I did not want to loose the whole skylights (well the DW did not). 132 in the skylight, 90 in the bathroom without the air on.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 09-06-2015, 05:04 PM   #17
Texas Realtor's Avatar
I bought the aluminum bubble wrap insulation roll at lowes and cut to fit. Added the double side Velcro tape and holds throughout summer and take it off in winter. Tape removes fine
Texas Realtor is offline   Reply With Quote
Old 09-07-2015, 11:35 AM   #18
Use the insulating bubble foam cut larger than the opening, it is available in the home stores and use velcro strips to hold it in place.
john.tucson is offline   Reply With Quote
Old 09-07-2015, 11:50 AM   #19
Just to add another thought to this discussion; By painting the outside of the dome, it will probably have a much longer life. Strong UV will dry out the plastic used, and it will eventually crack. I had an 07 Durango, that lived most of its life inside a barn. But the dome eventually began to crack. The cracking might be due to several influences, such as vibration and flexing during travel, or it might have been installed in a flexed mode that contributed to the eventual cracking. But the cracks did not start or end at a screw hole. Both cracks were out in the "dome" area.
I think painting it white is a great idea. I may go ahead and paint the dome in my Silverback.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 09-07-2015, 12:00 PM   #20
Plain Old Member
Exactly why I used the proguard product. Did Liquid Roof on one, and another one of their products on another. Makes it more like the roof itself. Better than paint in my opinion, and a LOT thicker.
show, shower
