Old 06-30-2019, 07:04 AM   #1
How Often Do You Drain Your Hot Water Heater?
Going on quite a few trips during the summer with a few weeks of idle time between. Should I be draining my hot water heater after every trip?
Chester Hill is offline   Reply With Quote
Old 06-30-2019, 07:23 AM   #2
Not sure if it's right or not but in the 27 years we've been rving ( started 1992 ) we drain ours once a year when I winterize the rv. Flush it then also.
Greg in Michigan
2019 rockwood 2606ws
2018 Nissan titan xd Cummins turbo diesel
Greg in michigan is offline   Reply With Quote
Old 06-30-2019, 07:24 AM   #3
Crusadernoob's Avatar
I don't just for a few weeks.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37
Crusadernoob is offline   Reply With Quote
Old 06-30-2019, 07:29 AM   #4
Mr. Dan's Avatar
Greg in Michigan
Same here - we stayed in our trailer 111 nights last year so ours gets a good bit of use.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 06-30-2019, 07:31 AM   #5
Greg in Michigan
X2
Mark & Heather
Mountain Falls, VA
2019 Salem FSX 179DBK
firemedicmark is offline   Reply With Quote
Old 06-30-2019, 07:33 AM   #6
Greg in Michigan
X3
2011 Traverse LT, 3.6L, FWD
Old 06-30-2019, 07:33 AM   #7
Once filled at the start of the season, ours doesn't get drained until we winterize. There are often a few weeks in between trips. Never an issue.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 06-30-2019, 07:38 AM   #8
Same here. I drain it when I winterize.
When idle for a few weeks I do drain the water filter and set it on the counter to let it dry. I also sterilize the water lines to be on the safe side. I bypass the hot water heater when I sterilize.
Bob
2018 Rockwood Ultra Lite 2902WS Travel Trailer
HappyTrav is offline   Reply With Quote
Old 06-30-2019, 07:40 AM   #9
nomad297's Avatar
You stand more of a chance of rust developing inside of the tank (if it is not an Atwood water heater) without water in it than you do when it is full of water with a good anode rod.
I can’t think of any good reasons to regularly drain a steel water heater tank and leave it empty more often than necessary — “necessary” being when putting your RV away for winter.
Bruce
nomad297 is online now   Reply With Quote
Old 06-30-2019, 07:53 AM   #10
Canadian Member
I drain ours if the trailer is going to be sitting for 3 weeks or more between uses. My concern is stagnant water in the tank. I drain the water system through the low point drains for the same reason. Make sure you put the WH in by-pass mode before draining the low point drains to avoid any loose stuff in the WH from getting sucked into the water lines.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
drain, heater, hot water, water, water heater
