Old 12-21-2015, 09:56 AM   #11
tmmar's Avatar
Phil,
What gears are you talking about that you lube?
Tom and Margaret
2014 Berkshire 390bh-60
Old 12-21-2015, 10:23 AM   #12
dieselguy's Avatar
Assuming you're not sitting in Florida ... hydraulics most always sound a bit more strained this time of year due to cold temps. The fluid gets stiffer for no better word to pump. Still like said it is good practice to put dry lube on slide arms, gears, and even silicone type products on the slide seals. As for gears ... if your large hyd slide has the balance shaft underneath ... it has a rack on the slide arms and gears on the shaft itself. This setup is common on fivers and TT's
dieselguy is offline   Reply With Quote
Old 12-21-2015, 10:26 AM   #13
Originally Posted by tmmar View Post
Phil,
Tom it's the track the gears run in.
Old 12-21-2015, 01:20 PM   #14
tmmar's Avatar
Phil,
Thanks.
Tom and Margaret
hydraulic
