Old 05-29-2012, 11:11 PM   #1
2011 Berkshire 390BH-60
TaterColo's Avatar
Hydraulic fluid level?
Had a tough time putting the slides in after our Memorial weekend trip they made a lot if noise but moved in very slowly. I think it might be from low hydraulic fluid? This pic is with all slides in and all jacks up. There is no level indicator that I can see. Am I low on fluid or is this level correct? Thanks all!
TaterColo is offline   Reply With Quote
Old 05-29-2012, 11:20 PM   #2
TURBS's Avatar
Imo it should have more .
Old 05-30-2012, 01:06 PM   #3
tmmar's Avatar
The fluid level with all slides in and jacks up should be around the top indentation on the tank. That is where the indicator line is on mine.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-30-2012, 03:00 PM   #4
TaterColo's Avatar
Thx.
Old 06-02-2012, 09:23 AM   #5
Do you use any kind of special fluid or can I pick it up at anywhere?
langeraf is offline   Reply With Quote
Old 06-02-2012, 09:42 AM   #6
TaterColo's Avatar
Dextron III. You should be able to get it at any auto-parts store.
Old 06-02-2012, 09:48 AM   #7
Thanks. Thats what I currently use. Just want to make sure there wasn't some other super duper stuff that was better.
Old 06-09-2012, 07:54 AM   #8
Joker's Avatar
If your level has decreased, be sure to do a thorough inspection for leaks. I found one at a hose clamp, center of coach, extreme back end. I'm not sure what that metal box does, but it was slowly leaking oily fluid. Come to think of it, I think the fluid was clear, so probably wasn't hydraulic fluid. But anyway, check for leaks!
Joker is offline   Reply With Quote
