Old 11-08-2014, 10:18 AM   #31
The reservoir is 1/2 full so I need to put fluid in it until I get home. Do I just use ATF fluid?
jakedempsey is offline   Reply With Quote
Old 11-08-2014, 10:40 AM   #32
2011 Berkshire 390BH
Superchief's Avatar
I don't remember if it is ATF, others can confirm. Are your slides in or out and are you levelers up or down? The level in the reservoir is dependent on these conditions. You do not want to over fill the reservoir, as you will have a bigger mess (don't ask me how I know that). The following website may help: http://equalizersystems.com/files/sh...tion_Guide.pdf. There are also other guides on the www.equalizersystems.com site under support. Hope this helps! Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 11-08-2014, 10:44 AM   #33
Superchief's Avatar
Fill the reservoir fully with Dexron Transmission fluid. This is the same fluid used in GM vehicles.
Craig
Old 11-08-2014, 10:48 AM   #34
Awesome thanks! I had the slides in and Jacks up and it's about 1/2 full so need to get some fluid in there! Gonna have a mess to clean up when I get home lol.
Old 11-08-2014, 10:48 AM   #35
And thanks for the PDF.. Super helpful!
Old 11-08-2014, 10:52 AM   #36
tmmar's Avatar
But don't overfill it. There should be a line on the tank showing where to fill it to.
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-08-2014, 11:05 AM   #37
When all slides are in and jacks are up... When I unscrew that plug to replace the oring... Is it going to be under any pressure and spray fluid? I may just find a camping world on the way home and repair in the parking lot .. Unless it's gonna make a mess.
Old 11-08-2014, 11:08 AM   #38
Witch Doctor's Avatar
Ah it's just Camping World don't worry they are mess anyway.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-08-2014, 02:57 PM   #39
Hank, Not sure about testing at the top of a grade, but when Ed (wnytaxman) took his "B" endorsement driving test for New York State, the Examiner told him he should run a static test on the air brakes before any trips. Craig
Running a full static test at the start of every DAY is what the regs call for, IIRC. However, I know of NO driver that does more than check for 90-100+ lbs of pressure, before driving off (that's inside the cab.... outside a good driver will check slack adjusters, etc).
As far as top of steep grade checks, I was never taught what to do. If a driver does stop (most do not) he should check for overheated/smoking brakes, I'd guess.
When I drove there were almost no hills in the whole country that I could not descend SAFELY by down shifting and using the jake brake; it's just that doing it that way is much slower than using the brakes some. Also if raining or other bad traction conditions, DON'T do it, as you're only braking on one axle out of five.
Old drivers saying: You can descend a hill to slowly over and over; you can only descend a hill to fast ONCE.
Boowho??
boowho is offline   Reply With Quote
Old 11-27-2014, 12:38 AM   #40
New oring... Leak fixed! Thanks everyone!
390bh, hydraulic, leak
