Old 05-10-2014, 01:21 PM   #1
Hydraulic Slides "sticking" ??
Last week I mentioned that one of my LR slides came in quite sluggishly. I thought it was low house batts. BTW, I assume that everyone's kitchen slide looks like it's going pitch over and fall when it starts moving; quite unnerving the first couple of time I ran it in.
Anyhow, I now find that it runs slowly even with fully charged batts.
Anyone else had this happen?? I know there are grease fittings on the rotating shaft down in the mother-in-law suite. But I don't know if there are any other things that might need to be lubed down there.
Anyone?
boowho??
boowho is offline   Reply With Quote
Old 05-10-2014, 01:40 PM   #2
A friend of mine had this issue and was told to clean and lubricate the seals around the slide. He poo-poohed the idea but did it anyway. He was amazed that it made a big difference.
bkearney is offline   Reply With Quote
Old 05-10-2014, 07:59 PM   #3
ernest917's Avatar
Yeah.... I hate the heck out of how the kitchen slide opens.... You have to start then pause and let it settle Dow and then finish opening it.... It's the only slide i put a slide-loc on ....
ernest917 is offline   Reply With Quote
Old 05-11-2014, 12:56 PM   #4
Will try that as soon as it quits raining!!
Boowho??
Old 05-11-2014, 02:32 PM   #5
Gottawonder's Avatar
The other day I noticed both my kitchen & dining room had eased out a bit. Guess it'll be slide locks for both 'em.
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
Old 05-11-2014, 03:14 PM   #6
Mmnsc's Avatar
Hi Gotta
If your slides are starting to creep out, the bad news it will probably get worse. On mine I finanally had to have the anti-creep valve changed along with the hydralic cylindar. Make sure you travel with your safety bars as mine started to creep out as I was driving. I had to stop every 15 miles to bring it back in.
Mmnsc is offline   Reply With Quote
Old 05-11-2014, 03:36 PM   #7
What did he lubricate the seals with. One of my slides wouldn't move today. The motor was running but it wouldn't move. I went out side and noticed the rubber seals had folder in and part of it was twisted the other way. Fixed it and it opened fine so I can definitely see how they'd slow the slide or stop it from moving.
motodude79 is offline   Reply With Quote
Old 05-11-2014, 03:46 PM   #8
Red Wolf's Avatar
Manufacturer of our old TT (Jayco) said to use silicone spray lube. I gave all of the slide out seals a good coating after de-winterizing each February. Never had an issue. I plan on doing the same with the new Rockwood.
-Red
Big Bad Wolf - '15 Dodge Ram 2500HD 6.7 CTD / Reese 15k Pro
Wolf Den 3 - '14 Rockwood Signature Ultra Light 8280WS
Nights camped 2017: 12
Red Wolf is offline   Reply With Quote
Old 05-11-2014, 04:01 PM   #9
Protect All Slide Out Rubber Seal Treatment - Protect All 40015 - Slideouts & Storage Bays - Camping World
Old 05-11-2014, 04:06 PM   #10
Mmnsc's Avatar
Baby powder works well. I just put it on an old sock and rub it into the seals. As a "dry" lubrucant it does not build up dirt and make a sticky mess let using liquid spray silicone.
slide, hydraulic, slides
