Old 07-24-2015, 05:42 PM   #11
my mistake. I reread and now saw it was two different satellite dish not air and sat.
palmetto rogue is offline   Reply With Quote
Old 07-24-2015, 08:26 PM   #12
Motodad's Avatar
The easiest way to do this since sat receiver sends voltage to the dish will be to find the line that you would hook up local cable to. Put it on the A side of a AB switch and the roof dish on the B side. Common goes to the sat input on the receiver. If you notice half the channels missing you will have to remove AB switch. I'm not sure if the AB switch will pass the 13-18 volts to power the dish. Hope you understand this and it helps. If not I may be able to draw it out and send you a pic. Good luck!!!
Motodad is offline   Reply With Quote
Old 07-25-2015, 10:16 AM   #13
edgewant's Avatar
What about the push button switch that is for either OTA antenna or cable. Anyone know if it will pass the voltage the tailgater needs?
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 07-26-2015, 09:04 AM   #14
Try Markertek, they are a company geared to Audio-Video that has much more to offer tha RS.
Markertek | Audio and Video Equipment | Professional Broadcast Studio Equipment
Harold Fay is offline   Reply With Quote
Old 07-26-2015, 10:51 AM   #15
Motodad's Avatar
Off air button sends voltage to the off air ant on the roof. It won't work. Also I tried to pass power through AB switch and it will not. Easiest way to do this will be to use the cable in on the side and screw that lead to sat receiver
Old 07-26-2015, 02:15 PM   #16
bubbles's Avatar
I have the VIP211K receiver with my Tailgater and use an AB switch for switching my tailgater interconnect and there is no issue with the voltage requirement. The OP should be able to connect roof sat ant coax directly to one port (A) and tailgater coax directly to other port (B) and the switch output (TV SET) to cable in port of VIP211K receiver. Works for me. I have heard that splitters between sat antennas and receiver may cause issues but not a simple AB coax switch.
Old 08-02-2015, 08:31 AM   #17
edgewant's Avatar
I installed a power pass splitter on the cable in from the power bay. I intend to connect the tailgater to that cable input. The splitter is installed before the OTA/cable switch. One leg of the splitter goes to an A/B switch. The other side goes to the OTA/cable switch. The other input of the A/B switch is the roof dish. Gave this arrange a trial run by connecting my home dish to the cable connection in the power bay. Either dish will now pass signal to the receiver. The only thing I didn't try was the OTA antenna. I have no reason to doubt that it will work.
Thanks for everyones suggestions.
edgewant
mount, roo, roof
