Old 09-03-2015, 11:26 AM   #51
I-RV's Avatar
Originally Posted by Motodad View Post
Sometimes it does. I have a 4ft piece of hose that fits my on/off valve. I just stick it on and blow in it to stop the siphon. I know it's weird guys. But we were losing a lot of water. I now come home with water.
Motodad - You have a method that works for you, but still with lot of manual intervention, like having to connect a tube and blow. Give a try to my anti-siphoning; once done you do nothing. See post #1 and #39
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-03-2015, 11:31 AM   #52
Motodad's Avatar
Will do. Thanks
Motodad is offline   Reply With Quote
Old 09-03-2015, 11:51 AM   #53
Originally Posted by I-RV View Post
If your fresh water tank is connected like mine, the bottom 25 gallons cannot be used because the pump starts sucking air (see photos). This means we are carrying around 208 useless weight.
To get more water into the tank, you can fill it to the "F" light comes on, but this is only 83 gallons and with the bottom 25 gallons being useless, you have 58 gallons to use.
Next you can crawl down on the ground to take those blasted pins out of the latches to watch the tank fill. Now you have 75 useable gallons.
Rather then deal with those latches, I once just filled the tank until I saw water coming out of the overflow, beneath the RV. I shut the water off and was amazed that water kept coming out for several minutes. I quickly found out that the overflow siphoned the top 21 gallons out, leaving me with 79 gallons and 54 useable.
Well where is this going??? I cut 7 1/2 inches of the overflow tube off (from the floor up) that protrudes through the floor. Enlarged the hole (with rat tail file) for a 3/4" PVC pipe. stuck the cut overflow tube into it and hung it with a tie-wrap. Tried to use few tools.
Now the tank can blindly be filled until water comes out the tube. Then when the water is shut off, there will be no siphoning action. You will have 100 gallons with 75 useable.
I know that many do not want to carry 100 gallons, but for those that do, here is a filling method.
Guess until I get my coach and can crawl all over and under it to see what these beasts are made of I have a hard time to visualize some of these things. Why can't / don't the water outlet from the tank that feeds the coach come up from the bottom of the tank with maybe a small riser in the tank so that it won't let sediment in the line but yet let you use more of the dead 26 gallons in the tank ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-05-2015, 12:10 AM   #54
'11 390BH
Thats a good question, but I did this mod as well. Thanks I-RV! It took more time to get the tools out and back then it did to actually do it. That they didn't catch this is funny
Every neighborhood has one...in mine, I'm him!
kohersh is offline   Reply With Quote
Old 11-11-2015, 12:27 PM   #55
glevron's Avatar
If You Want More Fresh Water
Has anybody ever measure there freshwater tank, mines only holds 75 gals. 66"x44"x6" ATTACH]94110[/ATTACH][ATTACH]94110[/ATTA
Name:	ImageUploadedByForest River Forums1447266408.776405.jpg
glevron is offline   Reply With Quote
Old 11-11-2015, 01:22 PM   #56
Motodad's Avatar
Mine swells up at least 10 more gallons. Looks like it's about to pop. Lol. Then I shut the overflow valve off. After a half day of use I open the valve and no more siphone. Works great
fresh water, water
