Originally Posted by dan-nickie
Thanks Gordon. Sounds like it wouldn't be too hard to change the setting up a couple of times?
Adjusting the spline is easy. There is a plastic cover at the centre of the controls that pops off to expose the philips screw that holds the temperature control in place. Remove the the screw, taking care to not drop it down the drain. The control slides off and you can move it to a new setting on the spline. No magic necessary.
I'm confident that you and your wife will like this shower control.
BTW, you have to do this and more to winterize. Look to my instructions above on that, which is just a reversal of the installation.
