Old 04-23-2013, 08:04 AM   #1
Installed air fitting
There was a thread awhile ago about use of the on board air compressor and installing a fitting to hook an air hose to. Anyway I couldn't add to that thread, something about being more than 130 days old, however thought somebody might like to see my installation of my fitting. Installed on a 45 degree angle for easier connecting and to help water and debris that might get into the connector drain out. Also on the advice of someone on that thread, I installed a valve as an extra insurance measure should the connector ever fail.
speedmerchant is offline   Reply With Quote
Old 04-23-2013, 08:11 AM   #2
TURBS's Avatar
Just an fyi you can actually post to a thread xxxx days old you just have to click the box that says you understand that the thread is xxxx days old.
Btw looks good!
Turbs
Old 04-23-2013, 08:15 AM   #3
DanielJ's Avatar
Very nice. My 2008 390TS had one when I purchased it used last year. I set myself up with a homemade air chuck with pressure gauge and I use it all the time. When I use it to put air in my car tires I usually don't even have to start the MH engine since the residual air pressure in the tanks is enough.
2008 Berkshire 390TS
DanielJ is offline   Reply With Quote
Old 04-23-2013, 10:21 AM   #4
Btw looks good!
Turbs
Thanks Turbs, good to know!
Old 04-23-2013, 10:37 AM   #5
Mine had one too. Either the dealer or the factory put it in. I figured they all had that fitting. Do you have the one for propane behind the rearmost cargo door?
Boowho??
boowho is offline   Reply With Quote
Old 04-23-2013, 10:46 AM   #6
JBoyer's Avatar
That looks like a mod I need to do. Where did you get the valve? Any special procedures to install? Are those 1/4 fittings? THANKS!!!
2015 Landmark Newport
2015 Silverado 3500hd dually tow vehicle
previous rig
2008 Berkshire pusher
2010 Mini Cooper Convertible toad
2015 Nissan Frontier toad
JBoyer is offline   Reply With Quote
Old 04-23-2013, 11:39 AM   #7
Berkshire 390QS
NO3putt's Avatar
Guess I'm surprized that the unit didn't come with one. If you ever have to be towed they need to get air presure into the HM just to release the brakes. I'm I wrong?
Old 04-23-2013, 12:25 PM   #8
Towing
If your unit ever needs to be towed I will always recomend that the tow company cages the brake. There is a bolt on the side of the brake chamber for them to use. If not they should have some with them. I recommend you do not allow them to feed air into your system to tow as if there is ever a failure your brake will engage. Having your brake fully engage while being towed at 60 MPH will not be in your best interest. I am a heavy equiptment mechanic and have seen what happens when people take the short cuts. Hope you never need a tow...
Tazfriend is offline   Reply With Quote
Old 04-23-2013, 12:48 PM   #9
DanielJ's Avatar
Boowho??
Yes, I have the gas quick connect too. I don't have any appliances yet that will use that connection tho since my wife got us a Coleman road trip grill which needs high pressure gas.
Old 04-23-2013, 02:46 PM   #10
Just a brass ball valve, any hardware store should have them. I had some kicking around the shop. All fittings including valve are 1/4" except technically speaking the coupler on the end is for a 3/8" air hose but threads on the other end of it are 1/4 " size. You should also use a good quality thread sealer like the white Loctite or Permatex stuff. I used a different brand (can't remember) that needs to be heated to get off, pretty overkill, but hey.
James
