Old 11-30-2015, 02:20 PM   #21
Go Seahawks!
Subsailor's Avatar
Originally Posted by 5456Mich View Post
No Glenn, not those. They are referring to the cord male and female ends. The ones that twist to lock together.
I have always referred to those as wire nuts too, I guess I need to figure out what "twist connectors" you guys are referring to. Thanks!
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 11-30-2015, 03:36 PM   #22
A32Deuce's Avatar
Subsailor, the twist type connector like you would find on a dryer, stove, welder. One that would not pull apart. Nice toy , I have a 32 3 window.
A32Deuce is offline   Reply With Quote
Old 11-30-2015, 04:22 PM   #23
pashooter's Avatar
For those using wire nuts (THOSE "twist connectors") I would recommend you tape the heck out of them (around the wire nut and down along the wires) after installation with vinyl electrical tape. In theory wire nuts should not be used in a mobile or high vibration application as they can work loose, but taping eliminates that possibility. Forest River uses them (for example where my #6 power cord was spliced into the #6 stranded wire going to the power distribution panel) but taped them so it's all good. I did the same thing where I spliced into the leads coming from my generator to run over to the transfer switch.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2018: 6
pashooter is offline   Reply With Quote
Old 11-30-2015, 04:31 PM   #24
pashooter's Avatar
Nice blue wire nuts though !!
That's what you need for #6 wire... the big honkin' blue ones. I bought a pack at the home center and used three... probably never use the rest of them...
Old 11-30-2015, 04:38 PM   #25
Looks just like my install Joe.
Please, please, please, Berkshire's run a 50 amp system. If you don't have 50 amps don't post systems that are less. Somebody can get hurt if a Berk owner tried to do what that picture with the romex showed!
Paul
Paulie Boy is offline   Reply With Quote
Old 11-30-2015, 04:48 PM   #26
Paul
X2
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 11-30-2015, 05:14 PM   #27
Up grades
Originally Posted by pashooter View Post
I thought the same thing Subsailor... that I'd put it after the transfer switch to protect the coach from either shore power or generator power issues... I mean the thing even shuts down if the line frequency goes out of tolerance... in North America, at least, that's NEVER going to happen on shore power. Also, I figured the current monitoring feature would be handy to control the load if running on the generator. But the guys here convinced me to do it like they've advised you - before, so as to protect the transfer switch as well.
If you're interested, here are a couple of photos of my installation in my Coachmen Pursuit...
Our new 2016 Coachmen Pursuit 31BD
Nice coach and even nicer work. I envy people who make it "look" simple. If it was truly simple, I could do it!!
pdqparalegal1 is offline   Reply With Quote
Old 11-30-2015, 05:18 PM   #28
Dream
32 Ford 3 window, dream since I was 14 and reading "Hot Rod". Long time ago.
Old 11-30-2015, 05:45 PM   #29
A32Deuce's Avatar
When the Beach Boys came out with Little Deuce coup, I wanted one. Started mine in 82 from parts. First drove June of 83. 3pedals on the floor, 200000 miles, drag race it for fun and autocross it.
Old 11-30-2015, 05:51 PM   #30
One lucky man.
