Old 04-21-2014, 11:08 AM   #11
Kaadk's Avatar
Originally Posted by frankatp View Post
Thanks everyone. We need to get ready for 6-8 months on the road. Craig, if we are on the computer (with wifi hotspot) and a call comes in we lose or connection. Did I understand that correctly?
First that only applies if your using your smartphone for access and second it depends on which technology your carrier uses. I'm only certain with the Canadian carriers but watching US commercials they claim AT&T doesn't drop internet. Makes sense since they use GSM like my carrier (Rogers) and I can use both at once. They other form of cell service (CDMA) is supposed to be the one that drops internet when a call comes in. On the flip side I've heard that CDMA has better range than GSM so you should get better coverage between towns.
However if you go with a mifi, that's a separate device from the smartphone, so calls coming in aren't an issue.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 04-21-2014, 12:07 PM   #12
2011 Berkshire 390BH
Superchief's Avatar
Frank, I have Verizon. If I use my Iphone as a Hot Spot to connect to the Internet, and a call comes in on my Iphone, I loose the Internet connection. If I am using the Jetpack to connect to the Internet, I would not be using my Iphone as a Hot Spot, thus if a call came in on my Iphone, I would not lose the Internet connection on the Jetpack. Hope that helps. Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 04-21-2014, 12:11 PM   #13
kerrlakelover's Avatar
Basically, the jetpack is another "phone" line on your bill. And it's like Craig just said. We've had the mifi for a couple of years and it looks like mifi is now called jetpack.
Set Your Location
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 04-21-2014, 01:18 PM   #14
Superchief's Avatar
Frank. The other thing to consider, is if you already have an unlimited data plan and you add a Jetpack, they will put that on a data plan. So if you do have unlimited data presently, I would just activate Hot Spot for $30 per month on one of your phones and not get the Jetpack. Craig
Craig
Old 04-21-2014, 01:31 PM   #15
When we replaced our old I 4 phone with the 5s we lost our unlimited data plan thru Verizon. We have a jet pack we use and it adds 10 per month and shares our plan. Be careful to monitor your usage as it can add up very quickly. Verizon also has some strange policy on when the plan is changed and what direction you can go. You can add data but you can't go down in mid bill cycle. So if you have a 10g plan and are using 12 g you can go up to the next tier but if using only 5 g in the cycle to bad you can't go down and can't bank it.
Old 04-21-2014, 06:42 PM   #16
Another thing for those thinking of using their smartphone as a hotspot..... Under some plans, Verizon "frowns upon" doing this and will try to block you.
They don't want you using your data allowance for anything but the phone itself. This seems to be only when tethering via wireless instead of a USB cable BTW.....
Why?? Who knows!! You've paid for 2GB per month.... Why should they care how you use it???
There ARE ways to thwart their evil plans, however.
Boowho??
boowho is offline   Reply With Quote
Old 04-22-2014, 11:18 AM   #17
Gottawonder's Avatar
Verizon's Share Everything plan let's you use your phone as a hotspot without additional charge. I may or may not have used workaround apps in the past, but once I went to "Share Everything" it got simple. No fees, use the Verizon apps. Also, if you have an iPad with 4g that can function as a hotspot, and those are $10 a month on the plan vs the $30 or whatever for a Mifi.
Is your Garmin HD Digital Traffic compatible? If you so could add the HD receiver and not have to fool with cellular data at all... Was thinking "do you have to have a wifi connect to use the Garmin traffic? "
https://www8.garmin.com/traffic/
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
Old 04-22-2014, 11:31 AM   #18
The verizon MIFI Jetpack is ten$ a month and shares that same plan. The advantage is having it in all the time and not worrying about the phone battery going dead. For ten dollars I find it worth it. Again be careful of going over the plan. When using for everything it adds G bits fast.
Old 04-22-2014, 09:23 PM   #19
camaraderie's Avatar
To OP...
Suggest you read this article before making a decision. Seems like Millenicom uses the same robust Verizon network but gives a LOT more data for the bucks without impacting your Verizon phone and requires NO CONTRACT.
The Millenicom Verizon Hotspot Plan Survival Guide | Technomadia
Lots of good reviews on other boards. I have ZERO experience with this ...but this is the one I will try when we take off later this year.
camaraderie is offline   Reply With Quote
Old 04-22-2014, 09:59 PM   #20
Originally Posted by camaraderie View Post
To OP...
Looks interesting, and for full-timer looks really great... glancing at activation fees and reactivations it loses a little luster if you were gonna use it a month or so then shut it off and reactivate. I think I'd want to talk through THAT process with 'em. DEFINITELY a deal if you're hitting 10-20 gig of data a month consistently. Good catch.
If you have a verizon shared data plan, you can buy more data for the months you're traveling and keep it lower when at home.
