Old 12-16-2014, 08:36 PM   #11
Update: replaced the broken fan on the inside of the bay wall and still getting the fault. Have a few ideas what may be wrong: 1.) temperature sensor or 2.) if there is an internal fan on inverter that could be broken. Any ideas? Thanks!
-David
trekdave42 is offline   Reply With Quote
Old 12-17-2014, 08:50 AM   #12
I recently had the same fault issue. Also had no power to front or rear TV, wall outlet in the bedroom was dead. Checked and reset the breaker under the bed, and solved the problem.
Pat
Cudntherd
2011 Berkshire 390BH-60
cudntherd is offline   Reply With Quote
Old 12-18-2014, 07:33 AM   #13
Cudntherd,
Thanks for the info. I by passed the temperature switch and also temporarily rigged up a fan to the side of the inventor to blow air across the top. Ran TVs, lights and heat pump all night with no issues. Looks like the internal fan is broken. Will update once I dig more into the manual.
Old 12-18-2014, 07:39 AM   #14
rattleNsmoke's Avatar
Is there a reputable replacement for 'Magnum' brand? Perhaps someone will chime in. Those units aren't cheap.
http://rvpowerpartsplus.net/index.ph...FVIV7AodoRQAiQ
rattleNsmoke is offline   Reply With Quote
Old 12-18-2014, 08:38 PM   #15
dan-nickie's Avatar
Originally Posted by trekdave42 View Post
Cudntherd,
Sounds like you're hot on the trail :-)
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
inverter
