Old 06-13-2014, 10:01 AM   #1
Inverter getting hot
Does anybody have any experience with the inverter getting hot and shutting down. Even when I'm plugged into shore power and the inverter is off it's throws error code and turn some outlets and lights off. I have a 2011 bunkhouse with a 1500 magnum inverter
michell-n-scott is offline   Reply With Quote
Old 06-13-2014, 10:03 AM   #2
Herk7769's Avatar
This can happen when the inverter is overloaded.
What are you trying to use off it?
HAM CALLSIGN - KC3FFW
Old 06-13-2014, 12:11 PM   #3
It's happening even when the inverter is off and I'm plugged into shore power.
Old 06-13-2014, 12:12 PM   #4
I unplugged the coach last night to allow the inverter to cool down. Plugged in this morning , worked fine for only about a half hour before it kept tripping on and off.
Old 06-13-2014, 12:31 PM   #5
MOD Guy's Avatar
The converter is working even when plugged into shore power (all your 12volts lights work off of it). If it is getting hot, I would guess the cooling fan that moves the air around/over it is not working, causing the heat to build up. That's what I would check first.
Edit....Sorry, I see you are talking about your Inverter, not the Converter. My Bad.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 06-13-2014, 12:51 PM   #6
KyDan's Avatar
He's talking about INverter. Changes 12v dc to 120v AC.
Should not be doing much when plugged into shore power!
There must be a switch or something set wrong..... outlets should be
powered by shore power when available not the inverter.
I guess inverter itself could also be suspect.
Good luck finding the problem!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 06-13-2014, 01:12 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I was hesitant to comment but to me to it looks like the inverter is done.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-13-2014, 03:39 PM   #8
If it's a Magnum, then the converter AND inverter are all in one box. AFAIK.
As someone has already suggested, make sure your cooling fan is running.
Boowho??
boowho is offline   Reply With Quote
Old 06-14-2014, 03:22 PM   #9
Dropping off this week to a shop to check out
inverter
