Old 02-03-2015, 03:14 PM   #1
Scokat's Avatar
Inverter question
I have my berk at a campground been there since Jan 5. anyway, we were there for a week, then came back home. I went back down last week and occupied it for a week, paid my electric bill, $135.00 for 2 weeks of use, but we left the coach plugged in while we were gone. shut everything off and hit battery disconnect and the electric meter is still spinning like a bat out of hell. You can hear the magnum inverter/charger humming. this doesnt sound right to me, just leaving the coach plugged in should not cost that much in electric? or am i wrong. any ideas?
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
Scokat is offline   Reply With Quote
Old 02-03-2015, 03:18 PM   #2
Iwannacamp's Avatar
IMHO unless there are extremely inflated usage rates on electricity I cannot understand that many KW's of electricity used in 2 weeks. Unless...you are running a ton of strip heaters. I would opt for an amp draw measure on the electric service if possible. You could figure the amp draw based on your converter and do the math.
2017 Puma 297RLSS
Old 02-03-2015, 03:20 PM   #3
Scokat's Avatar
we left the rv plugged in fridge on while we were gone. rate is .13 cents a kwh
Old 02-03-2015, 03:24 PM   #4
JTN8's Avatar
I leave mine plugged in at the house 24/7 and never noticed a difference in my power bill. Fridge stays on and never turn the batteries off. That does not sound right at all.
Jason
2014 Berkshire 390BH
2011 cadillac SRX
Old 02-03-2015, 03:43 PM   #5
Scokat's Avatar
should the invert button be lit or not when plugged in.
Old 02-03-2015, 03:59 PM   #6
JTN8's Avatar
Not lit, should be off
Old 02-05-2015, 08:22 PM   #7
Scokat's Avatar
ok, turned off everything in the rig, turned off the disconnect by the door, rv shut down but plugged in - used 22 kwh in a 24 hr period. why would the inverter be using so much energy? what else could it be? any ideas?
Old 02-05-2015, 08:48 PM   #8
Someone plugging into your exterior outlet to run their A/C or furnace? Someone is reading the wrong meter, it's rigged, or someone is pulling off your shore power. As you described it, it's nearly impossible for your rig to be pulling 22kwh's in a 24 hour period.
I would flip all of your breakers off and let it sit another 24 hours plugged in, or simply disconnect your shore power all together and see what they try and bill you for.
rana is offline   Reply With Quote
Old 02-05-2015, 10:52 PM   #9
2011 Berkshire 390BH
Superchief's Avatar
Scott, Did you turn the three switches off in the battery compartment? I believe that Ed (Wnytaxman) had a weird draw like yours when he was plugged in for winter storage. I don't believe he ever found the source, but I do know he ended up replacing all of his batteries. As they failed. Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 02-06-2015, 09:45 AM   #10
I-RV's Avatar
If your engine block heater is plugged in and the breaker on, it will consume a lot. It does not use the batteries, so the battery switches do not come into play. The block heater plug is in the rear compartment where the transfer switch is.
Hank
I-RV is offline   Reply With Quote
Old 02-06-2015, 10:56 AM   #11
Scokat's Avatar
i am not with the rv right now. does anyone or can anyone post a pic of the block heater plug so i can have my sister check the unit to see if its plugged in.
Old 02-06-2015, 11:01 AM   #12
fonzie's Avatar
Is your water heater turned off electric?
Fonzie
Old 02-06-2015, 11:03 AM   #13
Scokat's Avatar
it is turned off, propane instant hot water, no tank. alll power off, disconnet switch off.
Old 02-06-2015, 05:51 PM   #14
JTN8's Avatar
The block heater plug is in the same compartment as the 50 amp cord and inverter. It is a outlet and a plug. If the plug is in the outlet, this would explain your drain in power. Unplug it and all should be well.
Jason
Old 02-07-2015, 01:56 PM   #15
Scokat's Avatar
so, figured it out, thanks for the help. turned everything off, power disconnect off, coach used 23-25 kilowatt hrs in 24 hrs. Checked the block heater and it was plugged in.
Unplugged block heater, everything off, disconnect switch off, 24 hr usage was .8 - 1 kwh in 24 hrs.
Old 02-07-2015, 02:15 PM   #16
Superchief's Avatar
Great find!!! Don't you just love this forum!!
Craig
inverter
