Old 03-18-2011, 12:03 PM   #1
2011 Berkshire 390BH-60
TaterColo's Avatar
IPHONE4 to Jensen VR209TQ
I have searched and searched. I did find out the Amarazano had a solution but I cannot find the correct parts. And I cannot reply to his thread as it older than 110 days.
Quote from amarazano - "I purchased an adapter from Scosche for $18 from Amazon and problem solved!
Seems Apple switched pins for Power at one point and this Jensen product was before the change,
We tested it out on the drive up and over the weekend. Again for about $50 you can plug your iPhone / iPod directly into the dash radio. You can control and see the song/artist on the radio - great deal!! "
Can I get a part number of the parts or a direct link to the part?
Thanks!
TaterColo is offline   Reply With Quote
Old 03-18-2011, 10:19 PM   #2
amarzano's Avatar
Hi!
Well you need two things really.
- iPod cable from Jensen. I got mine from Jensen direct. This will plug into
The back of your head unit.
- iPod adapter from Scosche. You can search Scosche passPort on
Amazon. this will allow the iPhone to charge while connected.
Good luck!
Cummins ISB 360hp/800ft-lbs DEF
Allison 3000
amarzano is offline   Reply With Quote
Old 03-18-2011, 10:50 PM   #3
TaterColo's Avatar
Thanks. I found both and have them on order. I'm just wondering where I should have the cable come out of so it looks good.
Old 03-19-2011, 11:40 AM   #4
amarzano's Avatar
There are two black plastic plugs on the bottom of the console near the cup
Holder. I popped one out and ran the cable thru it.
You do know the top panel of the console just lifts up allowing you to access the Jensen and connecting the cables..
Allison 3000
Old 03-19-2011, 12:42 PM   #5
TaterColo's Avatar
Thanks I was about to pull the radio.
Old 03-19-2011, 08:30 PM   #6
amarzano's Avatar
This is why we talk.. :-)
Allison 3000
