Old 02-07-2016, 09:08 PM   #11
I have had 13 defective LED's replaced on my 2016 Berkshire 38A
smain980 is offline   Reply With Quote
Old 02-07-2016, 10:16 PM   #12
Is this the very same LED lights that are supposed to last for ever? Say it ain't so!
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 02-07-2016, 10:18 PM   #13
I haven't changed any so far and they are all still bright, but I have one light that's flickering like crazy. Will have to change it out soon I guess.
Old 02-08-2016, 08:25 AM   #14
I-RV's Avatar
I realize a lot of you have had trouble with LED lights, however my 14 in the front room have been good for four years. Over an interval they must have been getting dimmer until such a point we realized is it our eyes or why is it so dark in here. I di not believe it is the LED's themselves but maybe the dimmer control.
Have gotten some good suggestions here. I posted to see if anyone else has had the same problem
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 02-08-2016, 09:15 AM   #15
7 Year Class A RV'er
LED lights are great, but even the manufacturer told me they had a bad batch that were being replaced. I think that batch may be bigger than they thought. I spoke with a fellow selling LED fixtures at the Tampa RV show last month and he was aware of the issue, too; even told me the name of the manufacturer when I mentioned it (ITC). FR says they're replace them, but they won't send them to me - I have to take them into the dealer for replacement. My dealer's service folks stink, so I've been holding off. Trying to persuade the dealer right now to order and send them to me for installation. At least then I can do it in less than the six weeks it would likely take them!
2015 Legacy SR340 360RB
Old 02-08-2016, 11:03 AM   #16
I-RV's Avatar
Originally Posted by RKNOLA View Post
Hank
If you are handy with a multi meter you can compare the voltages at both dimmers, sounds like it could be a dimmer switch issue.
Rick
As Op of this thread, I was hoping that someone had the same problem and had solved it. It doesn't appear so.
Therefore, I dug out my digital voltmeter and investigated the dimmer switch.
I found that both the bedroom and living room has the same control; namely:
American Technology Components Inc.
AH-SLD-5-LS01
W/O: 101272 Rev A
My voltage readings were:
Batttery: 13.6V
Living Room Dimmer
Supply (Red to Black) : 13.28V
Dimmer Hi (White to Black): 0.89V
Dimmer Lo: (white to Black): 15.28V
Bedroom Dimmer
Supply: 13.27V
Dimmer Hi: 0.90V
Dimmer Lo: 17.60V
Now I am perplexed. First with the lights Hi (brightest) the control voltage is the lowest. Secondly, with the lights Lo (dim) the control voltage is even higher then the battery - LOL
I am wondering if there is a control module somewhere! I guess that I need to get with FR.
Hank
Old 02-08-2016, 11:50 AM   #17
tmmar's Avatar
In my '14 390bh, I saw a control module which if I remember correctly, is in the cabinet under the bathroom sink.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 02-08-2016, 11:59 AM   #18
Jim Schings's Avatar
Originally Posted by Eagle-751 View Post
hope this helps, Led's are not know to get that much dimmer.
? Very common issue. LED's DO get dimmer, and the driver circuits go bad causing dimming, and a multi LED panel can have one or more LEDs go bad.
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
Jim Schings is offline   Reply With Quote
Old 02-08-2016, 12:48 PM   #19
I-RV's Avatar
I called American Technologies and got some good information. The dimmer control, controls the ground side of the LED's using PWM (Pulse Width Modulation). The LED lights have their high side going to 12 volts directly.
This explains another problem that I had, which I didn't want to muddy the waters with my post. In the living room, I have eight celling lights and three soffit lights on each slide-out. I previously had a problem where my dinette soffit lights (controlled by the dimmer) and the table and sofa light go out. I found a fuse blew. This however got me to wonder how can the dimmer which controls all the living area lights, have one section go out. Now I know, namely the living area does have several different fused circuits that supply power to all the lights high side. However the lights that are dimmable have their low side going to the dimmer control. The table and sofa lights have their low side going directly to ground.
I may have to order a new dimmer control ($39.95) but only after another experiment where I remove the dimmer and wire the light circuit directly to ground.
Hank
Old 02-08-2016, 01:41 PM   #20
Hallen01's Avatar
Originally Posted by I-RV View Post
My LED ceiling lights seem to have gradually gotten dimmer ...anyone had the same problem and a remedy?
Hank
The heavily used ceiling light over the electric panel in the hallway went dim and stayed that way. I replaced it, and all is OK:
18-5040 65432-WW Diamond Group Overhead 906/921 Style LED Bulb
$14.88 x 2
$29.76
RV & Auto Parts
5365 Aztec Drive Unit 40
La Mesa, CA 91942
Phone: 6026351566
contact@rvautoparts.com
orders@rvautoparts.com
Double click on attached thumbnail to enlarge
Name:	LED Lamps.png
Hallen01 is offline   Reply With Quote
light
