Old 02-06-2016, 07:26 PM   #1
I-RV's Avatar
Is it my eyes or the lights?
My LED ceiling lights seem to have gradually gotten dimmer in the front room. When comparing the bedroom ceiling lights that are also on a dimmer control, they are bright and white, while the front room's lights are very yellow.
I would think that the problem is the dimmer control. Has anyone had the same problem and a remedy?
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 02-06-2016, 07:36 PM   #2
mikeborny's Avatar
Check your battery level. I had that happen and it turned out the batteries were not charging.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 02-06-2016, 07:37 PM   #3
Old Camping Squid
Eagle-751's Avatar
Two different color range light. The yellow looking is more a natural or soft white and of course the bright white is just that bright white. I hope this helps, Led's are not know to get that much dimmer.
Larry Collins { PM }
2006 F150 Supercab 5.4 Flex Fuel
2017 H-D FLHTK Ultra Limited
EZgo TXT and ClubCar Precedent golf carts
2009 Forest River Salem 30QBSS
U.S. Navy Veteran
Eagle-751 is offline   Reply With Quote
Old 02-06-2016, 08:10 PM   #4
I-RV's Avatar
My battery level is 13.60 volts. I am not implying that the LED elements have gotten dimmer, but the are dimmable by a dimmer control, just as the bedroom lights are. With the dimmer control fully up in the bedroom and front room, there is a noticeable lower light level in the front.
Hank
Old 02-07-2016, 12:08 PM   #5
RKNOLA's Avatar
Hank
If you are handy with a multi meter you can compare the voltages at both dimmers, sounds like it could be a dimmer switch issue.
Rick
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
RKNOLA is offline   Reply With Quote
Old 02-07-2016, 01:01 PM   #6
For a quick check I would swap the LEDs and see if they look the same. If the light is still dim up front, dimmer issue. If the dim lights are now in the back, the bulbs are possibly going bad or are a different color bulb.
POS Camaro is offline   Reply With Quote
Old 02-07-2016, 01:39 PM   #7
FF,Retired.
dimmers
You could also switch the dimmer controls.
Love13 is offline   Reply With Quote
Old 02-07-2016, 01:40 PM   #8
dan-nickie's Avatar
When I turn on the front lights, they default to a medium brightness. I have to turn them up to get them brighter. Wonder if yours are the same?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 02-07-2016, 02:09 PM   #9
I-RV's Avatar
I have a slide control and the intensity remains where the slide is positioned. I agree with the suggestions of checking the dimmer control's voltage or swapping with the bedroom control if that is possible because of their ratings. My front room has 14 LED's and the rear, only 4.
Thank's for the suggestions
Hank
Old 02-07-2016, 05:20 PM   #10
7 Year Class A RV'er
A lot if us are having big troubles with defective LED lights on the Legacy and similar due to some defective products. Take off the glass lens and be sure all the LEDs are lit. My 2015 currently has about 9 totally or partially bad lights.
2015 Legacy SR340 360RB
Old 02-07-2016, 10:08 PM   #11
I have had 13 defective LED's replaced on my 2016 Berkshire 38A
smain980 is offline   Reply With Quote
Old 02-07-2016, 11:16 PM   #12
Is this the very same LED lights that are supposed to last for ever? Say it ain't so!
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 02-07-2016, 11:18 PM   #13
I haven't changed any so far and they are all still bright, but I have one light that's flickering like crazy. Will have to change it out soon I guess.
Old 02-08-2016, 09:25 AM   #14
I-RV's Avatar
I realize a lot of you have had trouble with LED lights, however my 14 in the front room have been good for four years. Over an interval they must have been getting dimmer until such a point we realized is it our eyes or why is it so dark in here. I di not believe it is the LED's themselves but maybe the dimmer control.
Have gotten some good suggestions here. I posted to see if anyone else has had the same problem
Hank
Old 02-08-2016, 10:15 AM   #15
LED lights are great, but even the manufacturer told me they had a bad batch that were being replaced. I think that batch may be bigger than they thought. I spoke with a fellow selling LED fixtures at the Tampa RV show last month and he was aware of the issue, too; even told me the name of the manufacturer when I mentioned it (ITC). FR says they're replace them, but they won't send them to me - I have to take them into the dealer for replacement. My dealer's service folks stink, so I've been holding off. Trying to persuade the dealer right now to order and send them to me for installation. At least then I can do it in less than the six weeks it would likely take them!
Old 02-08-2016, 12:03 PM   #16
I-RV's Avatar
Originally Posted by RKNOLA View Post
Hank
Rick
As Op of this thread, I was hoping that someone had the same problem and had solved it. It doesn't appear so.
Therefore, I dug out my digital voltmeter and investigated the dimmer switch.
I found that both the bedroom and living room has the same control; namely:
American Technology Components Inc.
AH-SLD-5-LS01
W/O: 101272 Rev A
My voltage readings were:
Batttery: 13.6V
Living Room Dimmer
Supply (Red to Black) : 13.28V
Dimmer Hi (White to Black): 0.89V
Dimmer Lo: (white to Black): 15.28V
Bedroom Dimmer
Supply: 13.27V
Dimmer Hi: 0.90V
Dimmer Lo: 17.60V
Now I am perplexed. First with the lights Hi (brightest) the control voltage is the lowest. Secondly, with the lights Lo (dim) the control voltage is even higher then the battery - LOL
I am wondering if there is a control module somewhere! I guess that I need to get with FR.
Hank
Old 02-08-2016, 12:50 PM   #17
tmmar's Avatar
In my '14 390bh, I saw a control module which if I remember correctly, is in the cabinet under the bathroom sink.
Tom and Margaret
2014 Berkshire 390bh-60
Old 02-08-2016, 12:59 PM   #18
Jim Schings's Avatar
? Very common issue. LED's DO get dimmer, and the driver circuits go bad causing dimming, and a multi LED panel can have one or more LEDs go bad.
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
Jim Schings is offline   Reply With Quote
Old 02-08-2016, 01:48 PM   #19
I-RV's Avatar
I called American Technologies and got some good information. The dimmer control, controls the ground side of the LED's using PWM (Pulse Width Modulation). The LED lights have their high side going to 12 volts directly.
This explains another problem that I had, which I didn't want to muddy the waters with my post. In the living room, I have eight celling lights and three soffit lights on each slide-out. I previously had a problem where my dinette soffit lights (controlled by the dimmer) and the table and sofa light go out. I found a fuse blew. This however got me to wonder how can the dimmer which controls all the living area lights, have one section go out. Now I know, namely the living area does have several different fused circuits that supply power to all the lights high side. However the lights that are dimmable have their low side going to the dimmer control. The table and sofa lights have their low side going directly to ground.
I may have to order a new dimmer control ($39.95) but only after another experiment where I remove the dimmer and wire the light circuit directly to ground.
Hank
Old 02-08-2016, 02:41 PM   #20
Hallen01's Avatar
Originally Posted by I-RV View Post
My LED ceiling lights seem to have gradually gotten dimmer ...anyone had the same problem and a remedy?
Hank
The heavily used ceiling light over the electric panel in the hallway went dim and stayed that way. I replaced it, and all is OK:
18-5040 65432-WW Diamond Group Overhead 906/921 Style LED Bulb
$14.88 x 2
$29.76
RV & Auto Parts
5365 Aztec Drive Unit 40
La Mesa, CA 91942
Phone: 6026351566
contact@rvautoparts.com
orders@rvautoparts.com
Double click on attached thumbnail to enlarge
Name:	LED Lamps.png
Hallen01 is offline   Reply With Quote
light
