Old 01-16-2019, 01:47 PM   #1
Dragonship Captain
Oscarvan's Avatar
ISB "short" belt....
Most of the belt failures are the result of the AC compressor seizing up. I have a spare belt with me, but that doesn't help in the above case.
I have heard of people that carry a short belt that will take the AC compressor out of the loop.
I would love a size/part number.
Called Gaffney.... they heard of it but have no info.
ISB 340 6.7
Thanks.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 01-16-2019, 01:57 PM   #2
I understand what you are asking but I'll ask you does the A/C compressor not have a clutch on it?
Even if the compressor locked up, disabling power to the clutch would allow the pulley to turn, negating the need for a shorter belt. Now if the clutch pulley bearing locked up, that's a different story but you indicated compressor.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 01-16-2019, 02:26 PM   #3
Dragonship Captain
Oscarvan's Avatar
Not sure what fails..... just know that there have been several belt failures as a result of an "AC compressor failure"......
If the bearings seize up clutch or no clutch no matter....
Old 01-30-2019, 05:02 PM   #4
On way back from key west compressor failed belt broke side of route 95
Took out fan clutch and some other things had to leave coach till parts came in drove home in toed $2,600.00 later back on road
Blazer is offline   Reply With Quote
Old 01-30-2019, 07:11 PM   #5
Dragonship Captain
Oscarvan's Avatar
Yeah, that's the scenario......
So I'm trying to be able to do damage control if that happens by having the short belt that will get us home.....bypass the seized compressor.
Now, looking at this picture, I also see that there's a pulley there in place of the compressor, probably a generator setup.... I wonder if I could pull the compressor, hang it out of the way, mount the pulley and use a standard belt...... Pulley shouldn't be too expensive.
