Old 07-25-2015, 09:07 AM   #11
dan-nickie's Avatar
Originally Posted by tmmar View Post
The only real issue I have is this sound problem and occasionally when I turn the one mid-ship on, it will go on momentarily then go off.
If your setup is like mine, the mid and front TVs are connected via a HDMI splitter hooked to the satellite, basically hooking them together. HDMI has a feature called CEC (i think that's what it's called. It allows one TV to turn the other one off and on through the HDMI connection.
If I always point the remote at the front, both TVs will turn off and on simultaneously. If I point the remote at the mid TV it gets flaky sometimes.
I believe you can turn this feature off in the TV menu. Look for a CEC function.
ETA: just found this article on CEC
http://www.howtogeek.com/207186/how-...hy-you-should/
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 07-25-2015, 01:11 PM   #12
tmmar's Avatar
Dan,
I don't have HDMI cables. I have the regular RYW component cables. Old school for sure. Don't know why I didn't get HDMI cables. Also, pointing remote at TV over cab instead of at the mid-ship TV had no effect. Same issues.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-25-2015, 02:31 PM   #13
kingwood390bh's Avatar
Just so you you don't feel alone, my midship toshiba does the same thing. I have no explanation or solution
kingwood390bh is offline   Reply With Quote
Old 07-25-2015, 08:30 PM   #14
dan-nickie's Avatar
Bummer!
Dan
