Old 03-14-2012, 06:43 AM   #11
silver's Avatar
Regarding the no volume control on the Jensen VR187. This is an easy fix. There is a small ribbon cable connecting the front panel of the radio to the rest of the assembly that needs to be reseated. You will need to remove the radio and then disassembly the front panel from the radio. Unplug the cable then plug back in and it should work. The cable is very small and fragile so be careful. I have fixed two this way with the same issue.
silver is online now   Reply With Quote
Old 05-22-2012, 08:14 PM   #12
Tried everything that was suggested no fix. Called forest river and they replaced it with a refurbished one.
rpowell is offline   Reply With Quote
